7i85s differential Outputs as drive enables
- Doug Crews
- Thank you received: 9
24 Sep 2023 00:30 #281520
by Doug Crews
7i85s differential Outputs as drive enables was created by Doug Crews
Hi everyone,
The Spec sheet for the 7i85s states the "differential outputs can be used individually for interfacing single ended loads" and "When 7I85S outputs are used for drive enables or other safety related controls it is very important that the startup state disables the external equipment."
If I want to use an unused PWM TXN pin as a 5V sourcing output to enable a drive would I need to change the firmware on the 7i92T FPGA board, or is there already a hal pin that references it that I need to find and then map to it?thanks
Doug
Doug
- Thank you received: 7491
24 Sep 2023 17:42 #281554
Replied by tommylight on topic 7i85s differential Outputs as drive enables
Probably not, it should work as is if not designated a primary function.
Since i never used 7i85S, i am moving this to "driver boards", PCW knows everything about Mesa.
The following user(s) said Thank You: Doug Crews
- Thank you received: 5334
25 Sep 2023 02:31 #281571
Replied by PCW on topic 7i85s differential Outputs as drive enables
If you disable the PWM channel that drives the pin
( by setting num_pwms appropriately ), you can access the
pin as GPIO.
You also need to choose the connections and GPIO polarity
so that the drive is disabled when LinuxCNC is not running
pin as GPIO.
- Doug Crews
27 Sep 2023 00:45 #281684
by Doug Crews
Replied by Doug Crews on topic 7i85s differential Outputs as drive enables
Hi Peter, Thanks for the reassurance, and as usual all this information is in the Hostmot2 documentation. Could you confirm my process is ok. I made graphic of how I think this works.
1. 7i92t is flashed with 4 PWMGen modules via the bit file.
2. During l.cnc startup the loadrt config string in the hal file loads how many pwmgen modules you actually want to use. If I say num_pwmgen = 2 then the remaining 2 pwmgen module pins will be converted to GPIO pins.
3. With l.cnc running enter " halcmd show all hm2 " in terminal to show gpio name associations.
4. I then use the gpio names for mapping to other pins in the hal file and they get physically wired to the 7i85s TB pin according the 7i85s layout.
27 Sep 2023 14:17 #281720
That's correct.
A bit easier way to show the GPIO to terminal mapping is by using
a daughterboard specific pin list, like:
mesaflash --device 7i92t --addr 10.10.10.10 --dbname1 7i85s --readhmid
- Doug Crews
28 Sep 2023 03:02 #281763
by Doug Crews
HI Peter, I'm still going to need some more hand holding. I'm trying to use one of the unused PWM pins as an enable,
I get load time error "load erroor./ROBO_WELD_1.hal:113: Pin 'hm2_7i92.0.gpio.004.invert_output' does not exist
3178"
the line with error
hal file line 113 --> net y-enable joint.1.amp-enable-out => hm2_7i92.0.pwmgen.01.enable => hm2_7i92.0.gpio.004.invert_output
the config strig
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=4 num_pwmgens=2 num_stepgens=0 sserial_port_0=000001"
I tried to set the _invert_output to True but still same error. I tried to follow my procedure above, but I think I'm still lacking some basic hal mapping skills. Or I have a syntax problem I cannot spot.
-Doug
3178"
the line with error
the config strig
-Doug
28 Sep 2023 03:32 #281765
It works for me with a quick test:
halcmd -kf
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip=10.10.10.10 config="num_pwmgens=2"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:12:80:00
hm2_eth: discovered 7I92T
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): IOPort
hm2/hm2_7i92.0: IO Pin 004 (P2-03): IOPort
hm2/hm2_7i92.0: IO Pin 005 (P2-16): IOPort
hm2/hm2_7i92.0: IO Pin 006 (P2-04): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): PWMGen #1, pin Out1 (Dir or Down) (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): PWMGen #0, pin Out1 (Dir or Down) (Output)
SNIP
halcmd: loadrt threads
halcmd: addf hm2_7i92.0.read thread1
halcmd: addf hm2_7i92.0.write thread1
halcmd: start
halcmd: setp hm2_7i92.0.gpio.004.is_output true
halcmd: setp hm2_7i92.0.gpio.004.invert_output true
halcmd: setp hm2_7i92.0.gpio.004.out true
halcmd: getp hm2_7i92.0.gpio.004.in
FALSE
halcmd: setp hm2_7i92.0.gpio.004.out false
TRUE
halcmd -kf
SNIP
halcmd: start
FALSE
TRUE
28 Sep 2023 20:31 - 28 Sep 2023 20:34 #281815
the line with error
Sorry I did not notice this, You are trying to "net" a parameter
(hm2_7i92.0.gpio.004.invert_output) and that does not work.
It's likely you want:
net y-enable joint.1.amp-enable-out => hm2_7i92.0.pwmgen.01.enable => hm2_7i92.0.gpio.004.out
and possibly:
and possibly:
Last edit: 28 Sep 2023 20:34 by PCW.
- Doug Crews
29 Sep 2023 04:11 #281832
by Doug Crews
Thanks Peter, and yes this is a hal tutorial, sorry. I updated the hal file per your suggestion. L.cnc loads and the y-enable is showing mapped to gpio pin 004, . however the status of gpio 004 does not change when I push the enable button, and I do not read 5v across pins 2&3 on TB1 when enabled.
There is probably another fundamental hal mapping rule that I am ignorant of, or there is something with the direction. The pin is labeled as "out" but the hal config direction lists it as "IN" and there is the "invert_output" associated with the pin name, plenty of room there for a misdirection at my current knowledge level.
29 Sep 2023 05:04 #281836
Did you set the pin to output mode?
