7i85s differential Outputs as drive enables
30 Sep 2023 00:35 #281893 by Doug Crews
Replied by Doug Crews on topic 7i85s differential Outputs as drive enables
Got it!  I needed to switch to GPIO 005 (TX5) and invert it.
Pin 5 (TX5) is low when Lcnc is not running, Inverting it makes it low when lcnc is running but not enabled, and finally high when enabled.
The graphic shows the relationship between the Pin names, Pin parameters and  7i85s terminal block association.
Peter, thank you for pointing me in the right direction, and not just doing it for me.   This has been a very worth while and desperately needed hal / hostmot2 education for me.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Moderators: PCW, jmelson
