MESA 7i96 and 7i77
01 Oct 2023 08:29 #281970 by ihavenofish
MESA 7i96 and 7i77 was created by ihavenofish
SO, I have a 7i96s, with a 7i77 connected to it, and i flashed the 7i96s_7i77d.bin firmware..... But nothing changes in pncconf. Do not see any reference to it in the drop down.
What have I done wrong?
  • Moderator
  • Moderator
01 Oct 2023 09:27 #281973 by tommylight
Replied by tommylight on topic MESA 7i96 and 7i77
Probably nothing.
Make a config for 7i96S, start it, use hal show to watch the pins and see if there are 7i77 pins there.
You can also use mesaflash to check if the firwmare is ok, it should report 7i77 pins also.
01 Oct 2023 13:08 #281980 by ihavenofish
Replied by ihavenofish on topic MESA 7i96 and 7i77
it reports 7i96 (no s) and there is no sign of the 7i77 pins.
01 Oct 2023 13:34 - 01 Oct 2023 13:36 #281981 by PCW
Replied by PCW on topic MESA 7i96 and 7i77
You must have 5V and field power supplied to the 7I77 for
The 7I77s pins to be present
Also if it reports 7i96 pin names instead of 7i96s, you are like running a
too old version of LinuxCNC to fully support the 7I96S (2.9 is needed for full support)
Last edit: 01 Oct 2023 13:36 by PCW.
01 Oct 2023 13:46 #281983 by ihavenofish
I am running 2.9. It runs the 7i96s normally on its own. Still working fine even with the firmware change. MESAFLASH is what is reporting it as a 7i96. v3.4 something something? maybe it needs an update.
And no, I do not have field power on the 7i77. Only 5v. I wasn't using field pins but I guess it still needs it? I will connect that and see later today.
Thanks.
01 Oct 2023 14:04 #281984 by PCW
Yes, the 7I77 needs need field power power for the field I/O section pins to appear
(the analog section pis should appear with just 5V)
I would update Mesaflash
01 Oct 2023 14:12 #281986 by ihavenofish
Nothing appears at all from the 7i77. I think I do have the newest mesaflash from what I can tell.
I guess the cable could also be the problem. Not sure how to go about checking that. There are 2 leds lit up on the 7i77.
01 Oct 2023 14:51 - 01 Oct 2023 14:57 #281987 by PCW
What does
mesaflash --device 7i96s --addr [card_address] --dbname3 7i77 --readhmid
report?
Last edit: 01 Oct 2023 14:57 by PCW. Reason: forgot --readhmid
01 Oct 2023 15:02 #281988 by ihavenofish
thats where i see 7i96 (no s)
01 Oct 2023 15:15 #281989 by PCW
Yes, the low level HM2 FPGA name is still 7I96,
but that is not the card name. (and not used by the driver)
The hal names should all be hm2_7i96s.something
Moderators: PCW, jmelson
Time to create page: 0.114 seconds
