LitexCNC: firmware and driver for 5A-75B and 5A-75E
2 years 2 weeks ago #312378 by unromeo21
Any updates on the new version with shit register support ? It was anounced for 1st of March.
2 years 6 days ago #313252 by nubsaybot
Can anyone show an example of a hal and ini file on 3 axis step/dir (XYZ) without feedback, 1 pwm (spindle), 5 inputs (home - 3, probe, e-stop), 1 output (mist). I would like to try to connect the simplest CNC3018. If you tell me or direct me where to look at a similar example, I will be very grateful
1 year 10 months ago #317166 by Lisov_R
Good day! Tell me, is a gigabit port absolutely necessary or is 100Mb enough? How important are the jitter readings in the test?
1 year 10 months ago #317171 by Cant do this anymore bye all
No gigabit is not required, the mesa boards do not support this speed.
As no based thread is required jitter is not a major issue, under 100000ns will work.
The following user(s) said Thank You: Lisov_R
1 year 10 months ago #317172 by Lisov_R
I just ordered this board and am gathering information. Has anyone tried flashing it with the USB-Altera-Blaster STM-32?
1 year 10 months ago #317173 by Cant do this anymore bye all
After using a USB-blaster and a ft2232 board, Ive found the ft2232 board to be the more reliable.
After messing around with the colorlight boards I found they needed quite a bit of rework for use.
So I went with a Spartan 6 dev board and some custom boards and I was able to use Mesa 7c81 firmware built to suit.
Moderators: PCW, jmelson
Time to create page: 0.108 seconds
