1/3: Issue partially fixed!!
Thanks a lot for your quick feed back, PCW
I tryed the same procedure with linuxcnc 2.6 and 2.8 with the same bad results: no comunication
Just made a try with a live 2.9 linuxcnc version and comunication between Linux and the 7i92 card is ok now.
2/3: Wrong bitfile destination device: 6s1x9tqg144, it should be T20F256
Furthermore, i Just keep on trying to write the firmware for generical parallel cards
mesaflash --device 7i92t --verbose --write 7i92_PROB_RF_x2d.BIT
I had an error message saying
"wrong bitfile destination device: 6s1x9tqg144, it should be T20F256"
Attachment not found
i found this threat from PCW saying it is necessary to activate the boot sector to be re-written
forum.linuxcnc.org/27-driver-boards/3769...w-to-fix-jtag#148992
But i think the message might related to the bitfile i am using is for a mesa 7i92 or a 7i92T instead of the one for the actual 7i92TM i have.
The so called T20F256 seems to be the FPGA IC model by Trion used in the 7i92TM mesa card.
www.digikey.es/en/products/base-product/.../2134/T20F256/336321
Shall i ask how to enable mesaflash to write the boot sector?
Should i just execute :
mesaflash --device 7i92t --verbose --fallback --write 7i92_PROB_RF_x2d.BIT
If not, in case the error message is related to the wrong FPGA device, where should i find a compatible 7i92_PROB_RF_x2d.BIT for the T20F256 IC installed in the mesa 7i92TM??
3/3: How to avoid using Firmware bit files
Alternatively:
- Is there a way to avoid using this firmware?
- Should i just get a new breakboard supported by default in the list of the cards of LinuxCNC?
This is the first time using a mesacard so it all lis quite new to me.
Thanks in advance for all the assistance!
