- Thank you received: 4153
Mesaflash is s seperate install to linuxcnc and it will not be up to date in Debian 12. It does exist in the Linuxcnc repositoryyesterday i installed a fresh debian bookworm with 2.9 suplied form the downloads section
FALLBACK INDICATION
Mesa’s supplied fallback configurations blink the red INIT LED on the top right hand side of the card if the primary configuration fails and the fallback configuration loaded successfully. If this happens it means the user configuration is corrupted or not a proper configuration for the 7I92s FPGA. This can be fixed by running the configuration utility and re-writing the user configuration.
FAILURE TO CONFIGURE
The 7I92 should configure its FPGA within a fraction of a second of powerapplication. If the FPGA card fails to configure, the red /DONE LED CR2 will remain illuminated. If this happens the 7I92s EEPROM must be re-programmed via the JTAG connector or (faster) JTAG FPGA load followed by Ethernet EEPROM update.
