mesa 7i33 7i37
06 Mar 2025 20:12 #323365 by PCW
Replied by PCW on topic mesa 7i33 7i37
Originally all 50 pin FPGA cards were made to be pinout/functionally compatible with OPTO22
relay modules. These are all active low. Some 50 pin cards have plug-in pullup resistors that
you can reverse to change from pullups to pulldowns.
Its also a side effect of Xilinx FPGA characteristics where you can define pre-configuration
pullups but not pre-configuration pulldowns.
06 Mar 2025 21:38 #323372 by vre
Replied by vre on topic mesa 7i33 7i37
7i80hd pullups are removable can remove them to do outputs active high ?
What about internal pullups must disable them also ?
06 Mar 2025 21:52 #323375 by PCW
You can remove the resistor networks and install them in backwards
to have pulldowns rather than pullups. I would not simply remove them.
If you do this you should also disable pre-config pullups (W3 down)
Note that you should not do this for Mesa daughtercards that are active low
The following user(s) said Thank You: vre
06 Mar 2025 22:18 #323377 by vre
base pin1 is 5v and base pin10 is gnd
if connect resistor in reverse 5v will connected to port pins through last resistor.
Is it better to cut pin10 of resistor network ?
06 Mar 2025 23:47 - 06 Mar 2025 23:48 #323380 by PCW
No, just reverse to get pulldowns vs pullups.
You can cut pin 10 but it does nothing but waste a few mW.
Last edit: 06 Mar 2025 23:48 by PCW.
10 Mar 2025 01:49 #323587 by vre
7i80hdt that is not xilinx fpga has the pullup only limitation
or can configured both pullup and pulldown with weak internal resistors ?
10 Mar 2025 02:23 #323591 by PCW
Pullups and pulldowns are possible on both but only after configuration
Xilinx chips have the added option of pullups before being configured
10 Mar 2025 23:51 - 11 Mar 2025 00:00 #323640 by vre
What do you mean after configuration?
After loading firmware from flash memory?
When you powering fpga the firmware loads almost immediately...
How to enable xilinx weak internal pulldowns?
Last edit: 11 Mar 2025 00:00 by vre.
11 Mar 2025 00:32 #323643 by PCW
On Xilinx you can edit the .ucf file and add the "PULLDOWN" constraint
but the I/O pins will float during powerup/configuration.
For 50 pin cards, it's much easier to just reverse the pullup resistors
and the GPIO will be guaranteed to be low at all times (and with a known
pulldown resistance)
Moderators: PCW, jmelson
Time to create page: 0.222 seconds
