- Thank you received: 502
For this project 5 step/dir channels and some way to control a 3-wire RC servo motor. I'd go with a 6 channel Mesa card if it wasn't a little pricey and out of stock.How Many Axis do you need
little fun-project, almost without soldering, but works and is inexpensive
Crazy idea, what is the frequency of the spindle PWM signal on a 7i96 card? Can I co-op that to drive a RC servo. Or use a spare output and pulse at 50 Hz? Can the I/O handle that kind of duty cycle toggling?A 7I92TH/TF and a couple Mach 5 Axis BOBs could do this
(or even without the BOBs if you are careful...)
In my case even low res motion is better than stop to stop action. Out of curiosity what physical pins on a 7i96 would drive the RC servo.Mesa firmware includes a specific PWMgen for RC servos: RCPWMGen.
This can be added to any Mesa FPGA card. Standard PWMgens tend
to have low resolution when used for RC servos as the full scale
duty cycle of RC servos is quite low ( a few %)
