- Thank you received: 5334
Mesa 7I92TM goes offline shortly after starting LinuxCNC
2 years 6 months ago - 2 years 6 months ago #298099
Replied by PCW on topic Mesa 7I92TM goes offline shortly after starting LinuxCNC
Its not likely a cable issue, it's most likely a host Ethernet setup issue:
No static IP setup on the Ethernet port connected to the 7I92TM.
(The init light indicates the expected watchdog error you will get if
communications with LinuxCNC are lost)
Last edit: 2 years 6 months ago by PCW.
- DougM
2 years 6 months ago #298100
by DougM
Replied by DougM on topic Mesa 7I92TM goes offline shortly after starting LinuxCNC
Ok, the top shows ip a when it's dead, the bottom when it's alive
But I do have a question about configuration, In network config when I select Routes and check "use this connection only for resources on its network" I then lose my Gateway (it goes to blank and I can't enter one). If I un-check the box I can then re-enter the gateway.
Which is correct?
Thank you,
Which is correct?
Thank you,
- DougM
2 years 6 months ago - 2 years 6 months ago #298101
by DougM
Last edit: 2 years 6 months ago by DougM.
2 years 6 months ago #298102
Like tommylight said, it looks like you have two configurations
setup for your single Ethernet device, there should only be one
setup with static ip address, no gateway,no DNS servers no search
domains and ipv6 disabled.
All you normal network connections should go through your WIFI
wlp2s0
wlp2s0
The following user(s) said Thank You: DougM
2 years 6 months ago - 2 years 6 months ago #298103
You need to select "Manual" rather than Automatic on the IPV4 page
The following user(s) said Thank You: tommylight, DougM
- DougM
2 years 6 months ago #298104
by DougM
FIXED!!
Thank you so much for your help,
Time to create page: 0.949 seconds
