inmux mesa card 7i90
- telmoram
17 Apr 2024 22:59 #298509
by telmoram
Replied by telmoram on topic inmux mesa card 7i90
this message
Configuration Name: HOSTMOT2
BoardName : MESA7I90
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 7000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort PWM 0 /Enable (Out)
3 1 IOPort MuxedQCount 0 MuxQ-A (In)
5 2 IOPort MuxedQCount 0 MuxQ-B (In)
7 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 4 IOPort MuxedQCount 1 MuxQ-A (In)
11 5 IOPort MuxedQCount 1 MuxQ-B (In)
13 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
15 7 IOPort MuxedQCount 2 MuxQ-A (In)
17 8 IOPort MuxedQCount 2 MuxQ-B (In)
19 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
23 11 IOPort PWM 0 PWM (Out)
25 12 IOPort PWM 0 Dir (Out)
27 13 IOPort PWM 1 PWM (Out)
29 14 IOPort PWM 1 Dir (Out)
31 15 IOPort PWM 2 PWM (Out)
33 16 IOPort PWM 2 Dir (Out)
35 17 IOPort PWM 3 PWM (Out)
37 18 IOPort PWM 3 Dir (Out)
39 19 IOPort PWM 4 PWM (Out)
41 20 IOPort PWM 4 Dir (Out)
43 21 IOPort PWM 5 PWM (Out)
45 22 IOPort PWM 5 Dir (Out)
47 23 IOPort PWM 0 /Enable (Out)
IO Connections for P2
1 24 IOPort InMux 0 Addr0 (Out)
3 25 IOPort InMux 0 Addr1 (Out)
5 26 IOPort InMux 0 Addr2 (Out)
7 27 IOPort InMux 0 Addr3 (Out)
9 28 IOPort InMux 0 Data0 (In)
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P3
1 48 IOPort None
3 49 IOPort None
5 50 IOPort None
7 51 IOPort None
9 52 IOPort None
11 53 IOPort None
13 54 IOPort None
15 55 IOPort None
17 56 IOPort None
19 57 IOPort None
21 58 IOPort None
23 59 IOPort None
25 60 IOPort None
27 61 IOPort None
29 62 IOPort None
31 63 IOPort None
33 64 IOPort None
35 65 IOPort None
37 66 IOPort None
39 67 IOPort None
41 68 IOPort None
43 69 IOPort None
45 70 IOPort None
47 71 IOPort None
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: InMux
Version: 0
Registers: 5
BaseAddress: 7000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
1 48 IOPort None
3 49 IOPort None
5 50 IOPort None
7 51 IOPort None
9 52 IOPort None
11 53 IOPort None
13 54 IOPort None
15 55 IOPort None
17 56 IOPort None
19 57 IOPort None
21 58 IOPort None
23 59 IOPort None
25 60 IOPort None
27 61 IOPort None
29 62 IOPort None
31 63 IOPort None
33 64 IOPort None
35 65 IOPort None
37 66 IOPort None
39 67 IOPort None
41 68 IOPort None
43 69 IOPort None
45 70 IOPort None
47 71 IOPort None
- Thank you received: 5334
17 Apr 2024 23:23 #298510
Replied by PCW on topic inmux mesa card 7i90
Oops got to find another address maybe tommorow
The following user(s) said Thank You: telmoram
18 Apr 2024 00:23 #298516
Moved inmux to 0x61xx..0x65xx where it should not clash with anything
- telmoram
18 Apr 2024 01:04 #298519
by telmoram
Thanks, it is working.
Time to create page: 0.691 seconds
