Bricked Mesa 7i92T
06 May 2024 23:12 #299979 by danilom
Bricked Mesa 7i92T was created by danilom
Hi , I used dozens of Mesa cards during the years, but recklessly I managed to flash an old 7i92 firmware to 7i92T board , and yes it was with older mesaflash . red /DONE led is illuminated. Manual says EEPROM must be re-programmed via the JTAG. Any instructions how to do this and with what tool.
Thanks !
06 May 2024 23:42 - 06 May 2024 23:48 #299980 by PCW
Replied by PCW on topic Bricked Mesa 7i92T
You need the "Efinity" tools and a supported programmer
(we use the FT4232H MINI MODULE) and a 7i92t.hex file
(you can build the hex file from source or use the one here)
File Name: seveni92thex.zip
File Size:293 KB
You program the FPGA with seveni92t.hex via JTAG and then
(without power cycling) run mesaflash to re-init the card:
mesaflash --device 7i92t --addr 192.168.1.121 --write  7i92t_16m_fallback.bin --fallback
mesaflash --device 7i92t --addr 192.168.1.121 --write  7i92t_something.bin
Not a real lot of fun to do if you are not setup...
 If you are local, its probably worth shipping it to Mesa
to get re-inited as it takes us about 1 minute.
Oh, and update your mesaflash, the newer ones won't let you do this...
Last edit: 06 May 2024 23:48 by PCW.
The following user(s) said Thank You: besriworld, COFHAL
08 May 2024 09:01 #300096 by danilom
Replied by danilom on topic Bricked Mesa 7i92T
Thank you PCW very much, will try that and report back. I'm in Europe so will try to manage it with a help from a friend.
08 May 2024 09:55 #300100 by tommylight
Replied by tommylight on topic Bricked Mesa 7i92T
Did you flash it twice with the wrong firmware?
It has a fallback, so flashing it only once with wrong firmware will not brick it and does not require JTAG, just moving a jumper.
08 May 2024 15:20 #300131 by PCW
Unfortunately, Its entirely possible to brick a 7I92T with one write if
you use an old version of Mesaflash (that does not recognize the 7I92T)
The following user(s) said Thank You: tommylight, FPVUALAB
08 May 2024 17:54 #300145 by tommylight
That i did not know, thank you.
The following user(s) said Thank You: danilom
05 Nov 2025 20:59 #337912 by FPVUALAB
Replied by FPVUALAB on topic Bricked Mesa 7i92T
Hello! Please tell me how to update Mesaflash to the latest version and why it is missing in the latest version of LinuxCNC? Also, please tell me which firmware version I need to flash the board to get 4 axes with 4 encoders? Thank you very much!
05 Nov 2025 21:10 #337915 by PCW
What version of mesaflash and LinuxCNC do you have?
mesaflash --version
To install the latest LinuxCNC version, go to github.com/LinuxCNC/mesaflash
 then scroll to the bottom for "Quickstart" instructions.
05 Nov 2025 22:22 #337917 by FPVUALAB
LinuxCNC penultimate version (and possibly 2 versions before that)
Mesaflash 3.5.16 (was updated a little earlier because it did not recognise my board)
06 Nov 2025 00:08 #337922 by PCW
mesaflash 3.5.16 is the latest
If you want 4 stepgens and 4 encoders, what pinout do you want?
(If for a 7I85S you would use 7i92t_7i85sx2d.bin = config fir 7I85S with 4 stepgens, 4 encoders, 1 sserial port per connector)
Moderators: PCW, jmelson
Time to create page: 2.110 seconds
