7i96s +7i83 trough 7i44 is it possible?
- Masiwood123
- Thank you received: 93
13 Jun 2024 13:34 #302939
by Masiwood123
7i96s +7i83 trough 7i44 is it possible? was created by Masiwood123
- Thank you received: 5326
13 Jun 2024 14:01 #302940
Replied by PCW on topic 7i96s +7i83 trough 7i44 is it possible?
Yes you can do that but you might be better off
with a 7I92TM +7I77 or 7I97T
The following user(s) said Thank You: Masiwood123
- Thank you received: 426
13 Jun 2024 14:08 - 13 Jun 2024 14:09 #302941
Replied by Cant do this anymore bye all on topic 7i96s +7i83 trough 7i44 is it possible?
I have a 7i92
P1 > 7i76
P2 > 7i74 > 1 port to a 7i83 (for spindle control plus some extra "things") and another port to a 7i73
The 7i74 might be a better fit as it has a 25 pin connector that matches the 7i96s connector where as the 7i44 has a 50 pin connector, tho it wouldn't be impossible.
P1 > 7i76
Last edit: 13 Jun 2024 14:09 by Cant do this anymore bye all.
- Masiwood123
13 Jun 2024 14:10 - 13 Jun 2024 14:12 #302942
by Masiwood123
Replied by Masiwood123 on topic 7i96s +7i83 trough 7i44 is it possible?
thank you very much, I have a 7i96s , so I thought I'd use it in combination with a 7i74 i also have, so I thought about getting a 7i83, i only need it for two servo motors+ spindle, 7i83 it is cheaper variant in that case.
Last edit: 13 Jun 2024 14:12 by Masiwood123.
- Masiwood123
13 Jun 2024 14:14 #302943
by Masiwood123
sorry I made a mistake, I have 7i74 instead of what I wrote 7i44
13 Jun 2024 14:16 #302944
A custom cable wouldn't be difficult, if not mesa has this.
store.mesanet.com/index.php?route=produc...69_71&product_id=285
13 Jun 2024 14:16 - 13 Jun 2024 14:24 #302945
The issue with a 7I96S+7I74 is that there's nowhere to add the second encoder
(well you could have strange 7I96S+7I74 firmware that puts one differential encoder
on the RX lines of 3 of the 7I74s RJ45 connectors)
Edit: you need three encoders: X, Z, Spindle.
You could use a 7I96S+7I85+7I83 but a 7I96S+7I77 might make more sense
Last edit: 13 Jun 2024 14:24 by PCW.
The following user(s) said Thank You: Masiwood123, Cant do this anymore bye all
- Masiwood123
13 Jun 2024 14:20 #302947
by Masiwood123
thank you, I made a mistake, I have 7i74 instead of what I wrote 7i44
- Masiwood123
13 Jun 2024 14:23 #302948
by Masiwood123
thanks, then I will buy a 7i77 and I solved the problem with cards:)
- Masiwood123
09 Sep 2024 20:15 #309782
by Masiwood123
my friend just repaired the 7i77 that I had and broke it with a short circuit (he says it's a dc-dc converter), in case it's successful, I'll try to connect it with the 7i96s...my question is, in that case, can I use the spindle output and encoder from 7i96s plus mpg and I/o, and with the 7i77 also use the I/O plus analog signals for the drivers (siemens amplifiers)?
Time to create page: 0.355 seconds
