7I97T PWMGen Dither and Firmware Version
- gwond
1 year 7 months ago #324034
by gwond
Replied by gwond on topic 7I97T PWMGen Dither and Firmware Version
Thanks for the quick reply, problem resolved! Now I seem to be running into troubles configuring the stepgen on the 7i78. Do I need to call that board out separately or include stepgens in the board config for the 7i97T?
Here is what I have in the main.hal
loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="sserial_port_0=00000000 num_encoders=6 num_pwmgens=6 num_stepgens=0"
It is failing here: net joint-2-enable => hm2_7i78.0.stepgen.02.enable
main.hal:255 Pin hm2_7i78.0.stepgen.02.enable does not exist
- Thank you received: 5334
1 year 7 months ago #324037
Replied by PCW on topic 7I97T PWMGen Dither and Firmware Version
should be
net joint-2-enable => hm2_7i97.0.stepgen.02.enable
should be
Time to create page: 0.806 seconds
