So I just tried creating a config with pncconf again. When I don't designate any functions to the pins on the 7i84 linuxcnc will launch but not show the 7i84 in halshow.When i add a function to any 7i84 pin in pncconf linuxcnc won't start and i get this error message:
LINUXCNC - 2.9.3
Machine configuration directory is '/home/cnc/linuxcnc/configs/Alcor220CNC'
Machine configuration file is 'Alcor220CNC.ini'
Starting LinuxCNC...
libnml/buffer/shmem.cc 320: Shared memory buffers toolCmd and toolCmd may conflict. (key=1004(0x3EC))
libnml/buffer/shmem.cc 320: Shared memory buffers toolSts and toolSts may conflict. (key=1005(0x3ED))
libnml/buffer/shmem.cc 320: Shared memory buffers emcError and emcError may conflict. (key=1003(0x3EB))
Note: Using POSIX realtime
Found file(REL): ./Alcor220CNC.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:17:80:2f
hm2_eth: discovered 7I97T
hm2/hm2_7i97.0: Low Level init 0.15
hm2/hm2_7i97.0: Smart Serial Firmware Version 43
hm2/hm2_7i97.0: 51 I/O Pins used:
hm2/hm2_7i97.0: IO Pin 000 (TB3-04): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 001 (TB3-08): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 002 (TB3-12): PWMGen #2, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 003 (TB3-16): PWMGen #3, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 004 (TB3-20): PWMGen #4, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 005 (AN_ENA4): PWMGen #4, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 006 (TB3-24): PWMGen #5, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i97.0: IO Pin 007 (AN_ENA5): PWMGen #5, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 008 (AN-ENA0..3): PWMGen #0, pin Not-Enable (Output)
hm2/hm2_7i97.0: IO Pin 009 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 010 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 011 (TB1-07/TB1-15): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 012 (TB1-17/TB2-01): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 013 (TB1-20/TB2-04): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 014 (TB1-23/TB2-07): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 015 (TB2-09/TB2-17): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i97.0: IO Pin 016 (TB2-12/TB2-20): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i97.0: IO Pin 017 (TB2-15/TB2-23): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i97.0: IO Pin 018 (Internal EncMux): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i97.0: IO Pin 019 (TB5-13/TB5-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i97.0: IO Pin 020 (TB5-15/TB5-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i97.0: IO Pin 021 (TB5-17/TB5-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i97.0: IO Pin 022 (TB5-19/TB5-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i97.0: IO Pin 023 (TB5-21/TB5-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i97.0: IO Pin 024 (TB5-23/TB5-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i97.0: IO Pin 025 (Internal InMux0): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i97.0: IO Pin 026 (Internal InMux1): InMux Input Mux #0, pin addr0 (Output)
hm2/hm2_7i97.0: IO Pin 027 (Internal InMux2): InMux Input Mux #0, pin addr1 (Output)
hm2/hm2_7i97.0: IO Pin 028 (Internal InMux3): InMux Input Mux #0, pin addr2 (Output)
hm2/hm2_7i97.0: IO Pin 029 (Internal InMuxData): InMux Input Mux #0, pin addr3 (Output)
hm2/hm2_7i97.0: IO Pin 030 (TB4-15/TB4-16): InMux Input Mux #0, pin muxdata (Input)
hm2/hm2_7i97.0: IO Pin 031 (TB4-17/TB4-18): IOPort
hm2/hm2_7i97.0: IO Pin 032 (TB4-17/TB4-18): IOPort
hm2/hm2_7i97.0: IO Pin 033 (P1-01/DB25-01): IOPort
hm2/hm2_7i97.0: IO Pin 034 (P1-02/DB25-14): IOPort
hm2/hm2_7i97.0: IO Pin 035 (P1-03/DB25-02): IOPort
hm2/hm2_7i97.0: IO Pin 036 (P1-04/DB25-15): IOPort
hm2/hm2_7i97.0: IO Pin 037 (P1-05/DB25-03): IOPort
hm2/hm2_7i97.0: IO Pin 038 (P1-06/DB25-16): IOPort
hm2/hm2_7i97.0: IO Pin 039 (P1-07/DB25-04): IOPort
hm2/hm2_7i97.0: IO Pin 040 (P1-08/DB25-17): IOPort
hm2/hm2_7i97.0: IO Pin 041 (P1-09/DB25-05): IOPort
hm2/hm2_7i97.0: IO Pin 042 (P1-11/DB25-06): IOPort
hm2/hm2_7i97.0: IO Pin 043 (P1-13/DB25-07): IOPort
hm2/hm2_7i97.0: IO Pin 044 (P1-15/DB25-08): IOPort
hm2/hm2_7i97.0: IO Pin 045 (P1-17/DB25-09): IOPort
hm2/hm2_7i97.0: IO Pin 046 (P1-19/DB25-10): IOPort
hm2/hm2_7i97.0: IO Pin 047 (P1-21/DB25-11): IOPort
hm2/hm2_7i97.0: IO Pin 048 (P1-23/DB25-12): IOPort
hm2/hm2_7i97.0: IO Pin 049 (P1-25/DB25-13): IOPort
hm2/hm2_7i97.0: registered
creating ladder-state
./Alcor220CNC.hal:33: Pin 'hm2_7i97.0.7i84.0.0.input-00' does not exist
Running HAL shutdown script
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/cnc/linuxcnc_debug.txt
and
/home/cnc/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
LINUXCNC - 2.9.3
Machine configuration directory is '/home/cnc/linuxcnc/configs/basic7i97_2024-08-10'
Machine configuration file is 'basic7i97.ini'
emc/iotask/ioControl.cc 786: can't load tool table.
Found file(REL): ./basic7i97.hal
hm2_eth: ERROR: can't connect: Network is unreachable
hm2_eth: rtapi_app_main: Network is unreachable (-101)
./basic7i97.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./basic7i97.hal:9: /usr/bin/rtapi_app exited without becoming ready
./basic7i97.hal:9: insmod for hm2_eth failed, returned -1
Could not open command file 'shutdown.hal'
hm2: unloading
and
