7i97t with 7i84d connection problem
15 Aug 2024 14:51 - 15 Aug 2024 14:58 #307834 by fons
Replied by fons on topic 7i97t with 7i84d connection problem
beside the traditional limit switch for x and z the mpg and step speed control   i need another  44 digital input and 27 digital  output  that means  2 7i84
in the description of the 7i84 i see "The RS-422 interface at 2.5 MBaud is compatible with HostMot2s SSLBP smart serial interface which can support as many as 32 7i84 cards for a total of 1024 inputs and 512 outputs"  before you told me  the 7i97t suport only one 7i84 but you can use the  availabe  expantion port and one on the regular port  or both on de expantion port  ? thats not clear  to me
is it a good idea  to use a separate plc to controle the lathe and let the  7i97 do the nc of the axe ?
Last edit: 15 Aug 2024 14:58 by fons.
  • Moderator
  • Moderator
15 Aug 2024 19:42 #307855 by tommylight
Replied by tommylight on topic 7i97t with 7i84d connection problem
You would need a 7i74 to connect up to 8 SSerial boards, besides the one on the 7i97T.
If you can do some simple electronics, do as PCW suggested and get the chip he mentioned, that is much cheaper since you only need one more. If you end up needing more than one, get the 7i74, saves a lot of time and makes for a cleaner control box as it is very easy to wire in.
21 Aug 2024 11:36 #308314 by Krulli_Fräser
Replied by Krulli_Fräser on topic 7i97t with 7i84d connection problem
Final update on the topic:
a replacement 7i84 just arrived and I connected it in the same way. With the new card all inputs and outputs are working properly. I can see the card in halshow and it just works :)
Moderators: PCW, jmelson
Time to create page: 0.386 seconds
