Error while Running Linuxcnc
- rajsekhar
- Thank you received: 12
27 Aug 2024 08:53 #308780
by rajsekhar
Error while Running Linuxcnc was created by rajsekhar
I am using Mesa 7i92+7i76+7i84.
Machine is under software set up stage, wiring completed.
I encountered the attached error in photo. The system runs ok, but it is 4 or 5th occasion the error occured.
What is happening wrong? Is it softw
- Thank you received: 5330
27 Aug 2024 14:48 #308814
Replied by PCW on topic Error while Running Linuxcnc
The original error is a watchdog bite.
This means you have a latency issue
(or the watchdog timeout is set way too fast)
I would do a ping test:
ping -c 4 [card_ip_address]
sudo ping -c 30000 -i .001 -q [card_ip_address]
Where [card_ip_address] is the IP address of the 7I92 card
(probably 10.10.10.10 or 192.168.1.121)
The last command will take 30 seconds to complete
- rajsekhar
01 Sep 2024 13:13 #309146
by rajsekhar
Replied by rajsekhar on topic Error while Running Linuxcnc
the terminal emulator results are as follows:
raycnc1@debian:~/Desktop$ ping -c 4 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.219 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.113 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.116 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.116 ms
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3074ms
rtt min/avg/max/mdev = 0.113/0.141/0.219/0.045 ms
raycnc1@debian:~/Desktop$ sudo ping -c 30000 -i .001 -q 10.10.10.10
[sudo] password for raycnc1:
30000 packets transmitted, 30000 received, 0% packet loss, time 30070ms
rtt min/avg/max/mdev = 0.044/0.052/0.116/0.004 ms
Latency test value screen shot attached, ran with 10 GLXgear and one 4k movie for 2 hour.
As I am noway an expert of these parameters, are they ok?
And one thing I noticed, the monitor goes blank sometimes for a moment, probably power issue. Now can such momentary power issue to CPU and MESA card create problem? Or could there be any issue with software download (and installation) as I had such issue before.
01 Sep 2024 13:58 - 01 Sep 2024 14:51 #309148
The latency and ping tests look fine.
Momentary power loss could definitely cause loss of communications/latency
Also I am assuming you are running a 1 ms (1000000 ns)
servo thread, as a too fast servo thread might also cause these symptoms
Last edit: 01 Sep 2024 14:51 by PCW.
- rajsekhar
02 Sep 2024 01:59 #309182
by rajsekhar
Watch dog timer is 5ms, HAL file attached.
Does that require any change?
02 Sep 2024 02:01 #309183
What is the servo thread period?
- rajsekhar
03 Sep 2024 05:52 #309263
by rajsekhar
SERVO_PERIOD = 1000000
INI file attached.
INI file attached.
03 Sep 2024 14:52 #309291
OK so I'm not sure whats going on as the ping test looks OK
but somehow the host PC has lost communication with the 7I92 for
more than 5 ms
What is the host PC hardware?
What kind of Ethernet chip does the host have?
lspci -vv | grep -i eth
Will often answer this.
more than 5 ms
- rajsekhar
17 Sep 2024 14:20 #310312
by rajsekhar
The "lspci -vv|grep -i eth" output is as follows:
raycnc1@debian:~$ lspci -vv|grep -i eth
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 16)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
raycnc1@debian:~$
And a very important update:
Today I ran latency test for 2 hour almost, and shockingly Max jitter for both servo and base thread result found in order of 49,000,000 ns. Normally these values are in 20,000 ns~30,000 ns range.
What to do?
raycnc1@debian:~$
What to do?
- Thank you received: 1477
17 Sep 2024 20:01 #310342
Replied by Todd Zuercher on topic Error while Running Linuxcnc
Sometimes failing hardware can cause weird bad latency spikes, such as a harddrive that is on it's last legs and is about to fail.
Time to create page: 0.132 seconds
