New update on STMBL
2 years 1 month ago #309309 by Freak
New update on STMBL was created by Freak
Hey everyone! We've just released our version of STMBL .
It's still a work in progress, so please use it with caution.
I hope this can bring new life to this project where the original authors put a lot of effort.
I created a fork first, but then I realized I couldn't use LFS , so I manually copied it.
As for documentation, we'll publish a static website soon. Any help is welcome!
The following user(s) said Thank You: RotarySMP, Todd Zuercher, tommylight, vre, agdeutschman, freemoore, besriworld, transistorman, Pro_El, COFHAL and 4 other people also said thanks.
2 years 1 month ago #309310 by tommylight
Replied by tommylight on topic New update on STMBL
Nice, thank you.
What are the chances of implementing the Smart Serial protocol used by Mesa, that would simplify things, a lot.
ASUS ROG Crosshair VIII Impact - AMD X570
2 years 1 month ago #309331 by Freak
Replied by Freak on topic New update on STMBL
It was already implemented in the version 4 and still it is. I'm using 6 of these boards with smart serial to control a robot.
The following user(s) said Thank You: tommylight, pommen, besriworld
2 years 1 month ago #309335 by besriworld
Replied by besriworld on topic New update on STMBL
How much are the parts for this board?
2 years 1 month ago #309362 by Freak
Difficult to say, depends on location, quantities and many other factors, but I would say below 200$.
2 years 1 month ago - 2 years 1 month ago #309392 by vre
Replied by vre on topic New update on STMBL
This version is for 230vac - 325vdc?
Exists any version for 3phase 420vac - 600vdc? This can be done with only an igbt module for 600vdc and better isolation distances or needs more extensive modifications?
Are there assembled boards for buying?
What robot you control with these drives
because many robots have higher voltage servomotors.
Instead XT60PW connectors drives can be connected with copper strip and screw with rectifier like other servo systems?
Last edit: 2 years 1 month ago by vre.
Moderators: PCW, jmelson
Time to create page: 0.474 seconds
