7i76e step dir signal missing for stepgen type 0
05 Sep 2024 07:34 #309404 by Traken
Hello everyone, I'm trying to configure linuxcnc 2.10 and mese 7i76e and I don't have a step/dir signal at all, but when I switch stepgen to type 2, there is a signal, but it's probably not correct because the machine loses steps.
05 Sep 2024 08:57 #309411 by PCW
It probably means that you have the step time too short for
the drive to recognize the step pulses (type 2 is quadrature
so has square wave signals that are quite wide at slow speeds)
05 Sep 2024 09:33 #309414 by Traken
ok, but why don't I have a signal on Stepgen Type 0, the oscilloscope doesn't show anything
05 Sep 2024 09:39 #309416 by PCW
Do you see a signal with type 2?
What is the step length set to?
05 Sep 2024 09:41 #309417 by Traken
Yes i see signal type 2 step length 5us
05 Sep 2024 09:45 #309419 by PCW
Maybe you have the step length too short for the scope to catch
05 Sep 2024 09:52 #309420 by Traken
Is this correct for it to work on stepgen type 2?
05 Sep 2024 10:03 #309421 by PCW
All modes work (0,1,2), but the steplength setting
only  affects the step length in modes 0 and 1.
05 Sep 2024 10:15 #309422 by Traken
How can I diagnose why it's not type 0? Maybe it's the Ethernet cable's fault?
05 Sep 2024 10:18 #309423 by PCW
Its most likely a hal file setting thats wrong: The step length
Moderators: PCW, jmelson
Time to create page: 0.800 seconds
