7i76e step dir signal missing for stepgen type 0
05 Sep 2024 15:37 #309425 by Traken
Ok, I increased the step time and set it to type 0, it works, but I set everything to 10000
05 Sep 2024 15:40 #309426 by Traken
https://ibb.co/HCckPX5this is my driver's manualhttps://ibb.co/HCckPX5
05 Sep 2024 16:32 #309431 by PCW
I would probably set the step space and step length to 5000,5000
and dir setup and dir hold to 10000,10000 on that drive.
That is, double the minimum drive timings.
05 Sep 2024 18:45 #309448 by Traken
When setting step 5000 5000 dir 10000 1000 the controller does not read the signal at all, the oscilloscope also the minimum signal it reads is dir 6000 6000.
05 Sep 2024 18:52 - 05 Sep 2024 18:55 #309451 by PCW
Probably your scope setup
 Minimum step length on the 7I76E is one ClockLow cycle or 10 ns
The 4030 drive does require quite high drive current
so you may need to wire it single ended:
7I76E +5 to Drive STEP+, DIR+
7I76E STEP- to Drive STEP-
7I76E DIR- to Drive DIR-
Last edit: 05 Sep 2024 18:55 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.106 seconds
