- Thank you received: 5
So does this mean that the BLDC module doesn't output commutation before/during the startup indexing procedure? If commutation outputs are suppressed before index pulse is found I may have a problem. I was thinking that it could output them, even if they were off by a little, and hopefully it wouldn't jostle the motor around too much.The question is whether the drives can do preset velocity with no commutation.
This is what I'm thinking. I will try it as soon as I have time and report back.I think you are suggesting that you could supply "fake" commutation signals from LinuxCNC to the drive, and that might be enough to persuade the drive to start working?
