Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
1 year 11 months ago #314554 by bnet
Great, yes I have an unused 7i97. Let me know if you need any other info.
Thanks!
1 year 11 months ago #314563 by PCW
File Name: 7i97_dfabs.zip
File Size:91.59 KB
1 year 11 months ago #314575 by bnet
Great, thank you. I will flash it tomorrow morning and see what I can figure out.
1 year 11 months ago #314622 by bnet
Haven't gotten very far... can't seem to connect correctly to the 7i97 card. Here's what I know:
-Setup via 'edit connections' gui
-IPv4 settings as 10.10.10.11 netmask 8, checked 'use this connection only for resources on its network' under routes.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000     link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00     inet 127.0.0.1/8 scope host lo        valid_lft forever preferred_lft forever     inet6 ::1/128 scope host noprefixroute        valid_lft forever preferred_lft forever 2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000     link/ether 14:b3:1f:29:86:cd brd ff:ff:ff:ff:ff:ff     inet 10.10.10.11/8 brd 10.255.255.255 scope global noprefixroute enp1s0        valid_lft forever preferred_lft forever 3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000     link/ether f8:94:c2:8d:35:24 brd ff:ff:ff:ff:ff:ff     inet 192.168.18.29/24 brd 192.168.18.255 scope global dynamic noprefixroute wlp2s0        valid_lft 84629sec preferred_lft 84629sec     inet6 fe80::aa25:9683:6e06:688/64 scope link noprefixroute        valid_lft forever preferred_lft forever
When I ping 10.10.10.10 the LEDs flash on the 7i97 in a certain sequence and terminal gives:
From 10.10.10.11 icmp_seq=1 Destination Host Unreachable
No detection of ethernet board from mesaflash.
Pinging 192.168.1.121 does nothing, terminal hangs.
Jumpers W16 & W17 are both in low position.
Board was opened from factory seal this morning.
Let me know what to look for next. Thanks!
1 year 11 months ago - 1 year 11 months ago #314623 by PCW
set W17 up, power cycle  the 7I97 and try again
W16/W17 is 192.168.1.121
so ping of 10.10.10.10 will fail because there's no device with that address
and ping of  192.168.1.121 will fail because there's no route because of the host setup
Last edit: 1 year 11 months ago by PCW.
1 year 11 months ago #314624 by bnet
Yup, worked. Thanks. I will now proceed with the rest.
Moderators: PCW, jmelson
Time to create page: 0.329 seconds
