Mesa 7i96s / Network no longer working
  • schnellmued
  • New Member
  • New Member
12 Nov 2024 21:00 #314344 by schnellmued
Mesa 7i96s / Network no longer working was created by schnellmued
Hi all
I was happily using my 7i96s with LinuxCNC on my Mill. This week i powered on the machine and LinuxCNC was not able to connect. Ping 10.10.10.10 also got no response. So i picked a new 2m Lan Cable and connected the Laptop to the Mesa Card  (thought the cable from the cabinet might be damaged) - no Change :( I removed all connectors from the Mesa except the Power, still no change. I put the Mesa card on my bench, inspection did not show any damage. The Link Led is on, traffic led blinking from time to time. I did set the jumper W4/W5 down/down for 192.168.1.121 fallback ip (changed my laptop ip also ofc :D ), still no luck.
I did set the jumpers up/down for bootp and connected it to my router - it got stuck with red led on boot and no device did show in dhcp or the switch arp table.
The card was all the time inside a cabinet and there was no change to any electronics or firmware. I replaced the card with the one from my lathe - worked like a charm.
So the question: There is a firmware "7i96s_16m_fallback.bin", should i try to flash this on the card (the electronic guys at work have jtag equipment) ?
From the manual :  "Note that the card IP address is fixed at 192.168.1.121 when the IP select jumpers are in the UP,UP setting. If this fails, the 7I96Ss EEPROM must be re-programmed via the JTAG connector or (faster) JTAG FPGA load followed by Ethernet EEPROM update"
Anyone has done this before and could give me some hints please ? Thanks :)
schnellmued
12 Nov 2024 21:29 #314346 by PCW
Replied by PCW on topic Mesa 7i96s / Network no longer working
If you get the link LED (Yellow) on the RJ45, its not likely a firmware issue
but rather an Ethernet issue.
If you ping the card, do the green LEDs on the 7I96S count up?
The following user(s) said Thank You: schnellmued
12 Nov 2024 22:57 #314350 by tommylight
Replied by tommylight on topic Mesa 7i96s / Network no longer working
On the PC, what does
ip a
in a terminal return?
  • schnellmued
  • New Member
  • New Member
13 Nov 2024 17:08 - 13 Nov 2024 17:10 #314387 by schnellmued
Replied by schnellmued on topic Mesa 7i96s / Network no longer working
no, the green LED stay off.
If i connect to the other card in my lathe and ping it the green LED start to blink
schnellmued
Last edit: 13 Nov 2024 17:10 by schnellmued. Reason: missed quote button :D
  • schnellmued
  • New Member
  • New Member
13 Nov 2024 17:12 #314388 by schnellmued
ip a
xx@lxcnc-l540:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 3c:97:0e:d3:69:0e brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.2/24 brd 10.10.10.255 scope global noprefixroute enp0s25
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 5c:51:4f:8c:69:69 brd ff:ff:ff:ff:ff:ff
    inet 192.168.37.146/24 brd 192.168.37.255 scope global dynamic noprefixroute wlp2s0
       valid_lft 863940sec preferred_lft 863940sec
enp0s25 is the nic connected directly to the mesa card, wlp2s0 wifi to my home router
schnellmued
13 Nov 2024 17:39 #314391 by PCW
Sounds like something has gone wrong with the Ethernet section of the 7I96S card.
It should be repaired/replaced under warranty, Contact Mesa or your dealer for instructions
13 Nov 2024 17:45 #314392 by tommylight
That looks OK.
Did you use the Network Manager to set up the network?
If yes, you need to check the "use this connection for local ..... " not sure what exactly it says as i am on the phone.
That is for wired network only, IPV4 settings.
You also have a wireless network and if that connects before the Lan, it will send all trafic through wifi, if the above is not set for wired network.
  • schnellmued
  • New Member
  • New Member
13 Nov 2024 20:31 #314404 by schnellmued
That looks OK.
I think i used networkmanger, but iam also able to set the ip with ifconfig  :)
The Ip Stack will notice 10.10.10.10 is on the same subnet  as 10.10.10.2/24, so it will allways send packets for 10.10.10.0/24 to that interface. (unless statics routes exist)  It also worked for like >1 year in this config and it still works for the lathe mesa with the same ip as the "broken" one. I also tried some other Laptop, with no luck
schnellmued
  • schnellmued
  • New Member
  • New Member
13 Nov 2024 20:34 #314405 by schnellmued
Ok, i fear that too. But i will hook it to this Jtag debugger thingy at work, just for curiosity :)
Will post if i got some insights ..-
schnellmued
  • schnellmued
  • New Member
  • New Member
14 Nov 2024 18:24 #314471 by schnellmued
Ok, this is getting weird ... Yesterday i mounted the mesa card from the lathe into the mill, all worked fine... made parts for like 3+ hours .. Today i power up the mill again and the second mesa card network is also no longer working :( :( I dont understand, there was zero change to the electronics, since decenmber last year or sometime around.. (added 3d-probe)
The only power coming to the mesa card is 5v from a step down converter (24v->5v) which goes into the vc+/gnd and +5 to the input common.. all outputs go to a relay board. China spindle to pwm 0-10v . Xyz-axis Stepper drivers are on a seperate 48v psu, A-axis Stepper is on the 24v psu
This setup was working for ~1 year... Is there any chance some voltage spike (iam no electronics guy ;) ) could kill only the ethernet ?
schnellmued
Moderators: PCW, jmelson
Time to create page: 0.188 seconds
