Pi5 MESA 7c80: mesaflash can't see the card.
  • Platinum Member
  • Platinum Member
04 Jan 2025 02:33 #318012 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Pi5 MESA 7c80: mesaflash can't see the card.
No but it has been mentioned multiple times in multiple places (pretty sure I have mentioned it myself in this thread, maybe my posts are too long), why it isn't enabled by default is only something those that produce the images can say. I was a advocate for enabling it by default and disabling BT & sound
Or at least this should be mentioned on the download page, but people being people they can be lazy and only want the goodies or they only follow links to the actual downloads.
As you can see there is only one spi device interface that the 7c80 will respond to without a custom cable.
04 Jan 2025 02:40 #318013 by ccatlett1984
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
On a Pi <5, if you see anything in /dev/ spi*, spi is enabled...
Seeing as how i didn't have another pi5 with it already enabled to compare /dev/spi* to, it is a fair assumption for folks to make.
At the least, this needs a note/callout.
  • Platinum Member
  • Platinum Member
04 Jan 2025 02:51 #318015 by Cant do this anymore bye all
Honestly I forgot about the 10.0 entry. I really should have qualified this spidev0.xx & spidev1.xx.
Thanks for pointing this out.
Like anything on this forum people will overlook, not bother with it or a hundred other things that will make their life a misery. Look I used to make Mint based linuxcnc images, even including a READ.ME on the desktop people would still not bother to read it & ask the same questions over & over again, even aft they had been answered in the thread. Even updating the open post of the thread discussing these things didn't help.
Actually I'll jump over to Rods github and propose that the spi overlays are enable in the generated images. I really should have done this last year when they were originally being prepared.
  • Platinum Member
  • Platinum Member
04 Jan 2025 03:10 #318017 by Cant do this anymore bye all
Easier than trying to edit a post.
My fork was way out of date to create a pull request and I've kind of forgotten the code structure of the Image generating program. So I started a new thread asking if the next round of images could have the spi interface enabled, I also mentioned that you were a very patient user that had been lead astray by the spidev10.0 being created with the SPI interface, I guess it would be a idea to refer to it as the SPI user usable interface.
I think it would be an idea just to keep it to that topic alone, rather than requesting other software packages and mind reading abilities to be added (rod has declined the mind reading abilities on previous occasions). Tho to be fair in would be quite unkind for the poor old Rpi to read my mind.....I barley know what direction it is going. ;)
04 Jan 2025 04:31 #318023 by ccatlett1984
That sounds great, I am including this specific callout in the write-up that I am making (specifically for the 7c80, geared towards the Pi5). Since a start to finish guide doesn't exist in any single document.
The following user(s) said Thank You: dskinne6
  • Platinum Member
  • Platinum Member
04 Jan 2025 06:15 #318028 by Cant do this anymore bye all
It may help to mention that the 7c81, mesaflash & driver loading wise is the same. Apart from the difference in the name of the driver loaded the RPi4 is the same. You need to enable the SPI interface via config.txt
Hopefully you'll be able to put together a killer doc that people will read.
Good luck
28 Jan 2025 02:02 #319971 by ccatlett1984
I'm attaching the write-up i created.
  • Platinum Member
  • Platinum Member
28 Jan 2025 02:09 #319972 by Cant do this anymore bye all
Nice write up, new Rpi4 & Rpi5 images have measflash 3.5.10 included, as well as SPI being enabled by default. Might take a couple of days for the new images to go online.
28 Jan 2025 04:54 #319976 by rodw
point 6 sounds a bit dangerous to me because we are using a custom built kernel so who knows what might happen if you attempt to upgrade the OS version!
I would stick to just doing
sudo apt update
25 Aug 2025 19:41 - 25 Aug 2025 19:48 #333915 by probotix
Replied by probotix on topic Pi5 MESA 7c80: mesaflash can't see the card.
RPI5 OS with 7c81 Interesting note:
- Leaving config.txt alone creates only spidev10.0 and hal_spix works fine, but mesaflash does not.
- Enabling spi in config.txt (dtparam=spi=on) creates spidev0.0, spidev0.1, and spidev10.1, hal_spix works fine, and mesaflash works fine with --addr /dev/spidev0.0
It would appear that hal_spix just looks for the first spi device, whichever one it is, or scans all of them; and mesaflash explicitly requires it to be on spidev0.0.
Peter?
Last edit: 25 Aug 2025 19:48 by probotix.
Moderators: PCW, jmelson
Time to create page: 0.348 seconds
