Pi5 MESA 7c80: mesaflash can't see the card.
1 year 9 months ago #317848 by PCW
Note: Using POSIX non-realtime
Is it possible that this is a kernel issue?
1 year 9 months ago - 1 year 9 months ago #317849 by Cant do this anymore bye all
Could be. Looks like it could be a self built kernel, there are a couple of options relating to the real time kernel built.
Be interesting to know the origin of the installation. To get the hm2_spix driver I think you still need to build from source as the Rpi packages seem to have a July changelog.
Last edit: 1 year 9 months ago by Cant do this anymore bye all.
1 year 9 months ago #317851 by PCW
The kernel is not going to work anyway since its not realtime
The way I built my RPI5 test system was that I downloaded the RPI5 image
from the LinuxCNC website:
www.linuxcnc.org/iso/rpi-5-debian-bookwo...23-11-17-1520.img.xz
Installed it and then built linuxCNC master from source.
I wonder if something in config.txt could be an issue also... (since the cable and 7C80 seem to work)
1 year 9 months ago #317852 by Cant do this anymore bye all
If the SPI interface isn't enabled mesaflash will give
open: No such file or directory
So I would guess the SPI interface has been enabled and the nodes created under the /dev directory.
1 year 9 months ago #317853 by Cant do this anymore bye all
With regards to the RPi5 images Rodw linked to a new one on his google drive that seems to fix the screen issues. This is the one I used recently with my RPi5.
1 year 9 months ago #317855 by ccatlett1984
It is PREEMPT_RT
enabled RT when building.
Moderators: PCW, jmelson
Time to create page: 0.448 seconds
