- Thank you received: 3
FRESH START DEBIAN INSTALL ON 1/3/2025Could be. Looks like it could be a self built kernel, there are a couple of options relating to the real time kernel built.
Be interesting to know the origin of the installation. To get the hm2_spix driver I think you still need to build from source as the Rpi packages seem to have a July changelog.
Everything prior to today, was with the official Raspbian image.Something is amiss as the kernel is about 11 months newer than the image you linked to.
Now to clear things up.
1: have all your attempts been with the image you linked to.
2: if so what is causing the discrepancy with the kernel build date.
With the previous driver the kernel driver that was loaded on boot was unloaded by the Linuxcnc driver. I’m not entirely sure if it reloaded on exit.
