Pi5 MESA 7c80: mesaflash can't see the card.
1 year 9 months ago #317994 by PCW
I apologize, this is my fault, some production 7C80 cards ended up with
the wrong firmware. We can issue you a RMA for reflashing the card with
correct firmware. Sorry for the inconvenience.
The following user(s) said Thank You: rdtsc, Cant do this anymore bye all
1 year 9 months ago - 1 year 9 months ago #317996 by ccatlett1984
So, since i have a pi4 that can see the card, is it possible for me to flash the correct firmware?
I'd much rather not kill a week plus in cross shipping.
I'd like to try it here if it doesn't require super-specialized equipment, I've made JTAG cables before.
Last edit: 1 year 9 months ago by ccatlett1984.
1 year 9 months ago #317997 by PCW
You should be able to with the latest mesaflash
1 year 9 months ago #317998 by ccatlett1984
alright, putting the pi4 back in, let me know what needs done.
1 year 9 months ago - 1 year 9 months ago #317999 by PCW
If you can reliably access the card on the RPI4, you would
sudo mesaflash --device 7c80 --spi --addr /dev/spidev0.0 --write 7c80d.bit
sudo mesaflash --device 7c80 --spi --addr /dev/spidev0.0 --write 7c80fall.bit --fallback
(7c80d.bit and 7c80fall.bit are in the 7c80.zip file in /configs/hostmot2/)
the zip file is available from the store in the card specification tab
Last edit: 1 year 9 months ago by PCW.
The following user(s) said Thank You: rdtsc, ccatlett1984
1 year 9 months ago #318001 by ccatlett1984
From Pi4, dump of mesaflash BEFORE flashing:  pastebin.com/kf8iUXQY
dump of mesaflash AFTER flashing:  pastebin.com/5xm8FHpq
I forced a --reload in between each flash cmd, to validate the card took the firmware before moving on.
If this looks correct, I will proceed to swapping the pi5 back into the machine.
Moderators: PCW, jmelson
Time to create page: 0.459 seconds
