Pi5 MESA 7c80 WORKING
02 Jan 2025 00:02 #317829 by ccatlett1984
Replied by ccatlett1984 on topic Pi5 MESA 7c80: mesaflash can't see the card.
pi@linuxcnc:/ $ halcmd -kf
halcmd: loadrt hm2_spix
Waiting for component 'hm2_spix' to become ready.Waited 3 seconds for master.  giving up.
Note: Using POSIX non-realtime
hm2_spix: dlopen: /usr/lib/linuxcnc/modules/hm2_spix.so: undefined symbol: hm2_register
<stdin>:1: waitpid failed /usr/bin/rtapi_app hm2_spix
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hm2_spix failed, returned -1
halcmd:
02 Jan 2025 00:06 #317830 by ccatlett1984
pi@linuxcnc:/ $ uname -r
6.13.0-rc3-v8-16k+
pi@linuxcnc:/ $ uname -v
#1 SMP PREEMPT_RT Mon Dec 30 16:54:49 EST 2024
halcmd: loadrt hostmot2
hm2_spix: SPI0/CE0: Invalid cookie, read: 00000000 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d followed by a value less than 0x10000
hm2_spix: SPI0/CE0: No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
hm2_spix: rtapi_app_main: No such device (-19)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_spix
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_spix failed, returned -1
halcmd:
02 Jan 2025 00:12 #317831 by PCW
Does sound like a hardware issue.
Are there any red LEDs illuminated on the 7C80?
and is the 7C80 yellow power LED illuminated?
02 Jan 2025 00:21 #317834 by ccatlett1984
CR56 off
CR57 off
CR58 is lit yellow
02 Jan 2025 00:25 #317835 by PCW
So, unknown hardware issues...
One possibility is to send the 7C80 card/cable back to Mesa with an RMA
so it can be tested with a RPI5.
02 Jan 2025 00:27 #317836 by ccatlett1984
If I'm going to do that, I'd prefer to send in my pi5, so the whole thing gets validated as a set.
02 Jan 2025 00:59 #317839 by ccatlett1984
I have a pi4b with dead video out, connected and it's able to see the card. so we still have a config /driver issue with the pi5
halcmd: loadrt hm2_rpspi
hm2/hm2_7c80.0: Low Level init 0.15
hm2/hm2_7c80.0: Smart Serial Firmware Version 43
hm2/hm2_7c80.0: 54 I/O Pins used:
hm2/hm2_7c80.0:     IO Pin 000 (TB07-02/TB07-03): StepGen #0, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 001 (TB07-04/TB07-05): StepGen #0, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 002 (TB08-02/TB08-03): StepGen #1, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 003 (TB08-04/TB08-05): StepGen #1, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 004 (TB09-02/TB09-03): StepGen #2, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 005 (TB09-04/TB09-05): StepGen #2, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 006 (TB10-02/TB10-03): StepGen #3, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 007 (TB10-04/TB10-05): StepGen #3, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 008 (TB11-02/TB11-03): StepGen #4, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 009 (TB11-04/TB11-05): StepGen #4, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 010 (TB12-02/TB12-03): StepGen #5, pin Step (Output)
hm2/hm2_7c80.0:     IO Pin 011 (TB12-04/TB12-05): StepGen #5, pin Direction (Output)
hm2/hm2_7c80.0:     IO Pin 012 (TB03-03/TB04-04): IOPort
hm2/hm2_7c80.0:     IO Pin 013 (TB03-05/TB04-06): IOPort
hm2/hm2_7c80.0:     IO Pin 014 (TB03-05/TB03-06): IOPort
hm2/hm2_7c80.0:     IO Pin 015 (TB04-01/TB04-02): Encoder #0, pin A (Input)
hm2/hm2_7c80.0:     IO Pin 016 (TB04-04/TB04-05): Encoder #0, pin B (Input)
hm2/hm2_7c80.0:     IO Pin 017 (TB04-07/TB04-08): Encoder #0, pin Index (Input)
hm2/hm2_7c80.0:     IO Pin 018 (TB05-02): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7c80.0:     IO Pin 019 (TB05-02): PWMGen #0, pin Not-Enable (Output)
hm2/hm2_7c80.0:     IO Pin 020 (TB05-05/TB05-06): IOPort
hm2/hm2_7c80.0:     IO Pin 021 (TB05-07/TB05-08): IOPort
hm2/hm2_7c80.0:     IO Pin 022 (Internal InMux0): InMux Input Mux #0, pin addr0 (Output)
hm2/hm2_7c80.0:     IO Pin 023 (Internal InMux1): InMux Input Mux #0, pin addr1 (Output)
hm2/hm2_7c80.0:     IO Pin 024 (Internal InMux2): InMux Input Mux #0, pin addr2 (Output)
hm2/hm2_7c80.0:     IO Pin 025 (Internal InMux3): InMux Input Mux #0, pin addr3 (Output)
hm2/hm2_7c80.0:     IO Pin 026 (Internal InMux4): InMux Input Mux #0, pin addr4 (Output)
hm2/hm2_7c80.0:     IO Pin 027 (Internal InMuxData): InMux Input Mux #0, pin muxdata (Input)
hm2/hm2_7c80.0:     IO Pin 028 (TB13-01/TB13-02): SSR #0, pin Out-00 (Output)
hm2/hm2_7c80.0:     IO Pin 029 (TB13-03/TB13-04): SSR #0, pin Out-01 (Output)
hm2/hm2_7c80.0:     IO Pin 030 (TB13-05/TB13-06): SSR #0, pin Out-02 (Output)
hm2/hm2_7c80.0:     IO Pin 031 (TB13-07/TB13-08): SSR #0, pin Out-03 (Output)
hm2/hm2_7c80.0:     IO Pin 032 (TB14-01/TB14-02): SSR #0, pin Out-04 (Output)
hm2/hm2_7c80.0:     IO Pin 033 (TB14-03/TB14-04): SSR #0, pin Out-05 (Output)
hm2/hm2_7c80.0:     IO Pin 034 (TB14-05/TB14-06): SSR #0, pin Out-06 (Output)
hm2/hm2_7c80.0:     IO Pin 035 (TB14-07/TB14-08): SSR #0, pin Out-07 (Output)
hm2/hm2_7c80.0:     IO Pin 036 (Internal SSR): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7c80.0:     IO Pin 037 (P1-01/DB25-01): IOPort
hm2/hm2_7c80.0:     IO Pin 038 (P1-02/DB25-14): IOPort
hm2/hm2_7c80.0:     IO Pin 039 (P1-03/DB25-02): IOPort
hm2/hm2_7c80.0:     IO Pin 040 (P1-04/DB25-15): IOPort
hm2/hm2_7c80.0:     IO Pin 041 (P1-05/DB25-03): IOPort
hm2/hm2_7c80.0:     IO Pin 042 (P1-06/DB25-16): IOPort
hm2/hm2_7c80.0:     IO Pin 043 (P1-07/DB25-04): IOPort
hm2/hm2_7c80.0:     IO Pin 044 (P1-08/DB25-17): IOPort
hm2/hm2_7c80.0:     IO Pin 045 (P1-09/DB25-05): IOPort
hm2/hm2_7c80.0:     IO Pin 046 (P1-11/DB25-06): IOPort
hm2/hm2_7c80.0:     IO Pin 047 (P1-13/DB25-07): IOPort
hm2/hm2_7c80.0:     IO Pin 048 (P1-15/DB25-08): IOPort
hm2/hm2_7c80.0:     IO Pin 049 (P1-17/DB25-09): IOPort
hm2/hm2_7c80.0:     IO Pin 050 (P1-19/DB25-10): IOPort
hm2/hm2_7c80.0:     IO Pin 051 (P1-21/DB25-11): IOPort
hm2/hm2_7c80.0:     IO Pin 052 (P1-23/DB25-12): IOPort
hm2/hm2_7c80.0:     IO Pin 053 (P1-25/DB25-13): IOPort
hm2/hm2_7c80.0: registered
  • Platinum Member
  • Platinum Member
02 Jan 2025 01:43 #317843 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Pi5 MESA 7c80: mesaflash can't see the card.
I had issues with my RPi5 using SPI channel 0, dunno why, switching to SPI channel 1 resolved the issue. Not sure how you would resolve this without cobbling together a custom cable between the Pi and the 7c80.
you would have to use
loadrt hm2_spix spi_probe=2 config="insert your required config"
This is with my cobbled together 7c81 clone running hostmot2 firmware to suit the Spartan dev board.
02 Jan 2025 02:22 #317848 by PCW
Is it possible that this is a kernel issue?
  • Platinum Member
  • Platinum Member
02 Jan 2025 02:32 - 02 Jan 2025 02:39 #317849 by Cant do this anymore bye all
Could be. Looks like it could be a self built kernel, there are a couple of options relating to the real time kernel built.
Be interesting to know the origin of the installation. To get the hm2_spix driver I think you still need to build from source as the Rpi packages seem to have a July changelog.
Last edit: 02 Jan 2025 02:39 by Cant do this anymore bye all.
Moderators: PCWjmelson
Time to create page: 0.103 seconds
