Mesa 7i95T spindle step/Direction setup using stepgen
04 Jan 2025 15:30 #318085 by Sternfox
Hi All,
As the title suggests i have the Mesa 7i95T, I am wanting to use a AC servo as a spindle motor.
I am on version 2.9.2
I have the servo wired up correctly, i have validated this by plugging it into the Z axis socked and i get movement. The problem is that non of the configuration tools supports stepgen for the spindle only PWM, I have tried all the tricks i can find online to get this to work, like setting up for a different card then copy and pasting to my config but nothing works. no movement of the spindle.
I have attached my HAL and ini files if someone could kindly have a look.
04 Jan 2025 15:38 #318087 by PCW
I know pncconf does support step/dir spindles (but not the 7I95/7I95T)
You might use pncconf to create a say 7I96s configuration with a step/dir spindle
and steal the hal/ini spindle bits from that.
04 Jan 2025 16:10 #318097 by Sternfox
Thanks for the reply.
I have tried that already, and no joy, wasn't sure if it was a incorrect setting in my configs
04 Jan 2025 16:16 #318099 by PCW
As a first step try this:
[SPINDLE_0]
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 300.0
STEPGEN_MAX_VEL = 125.00
STEPGEN_MAX_ACC = 375.00
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0.001
MAX_OUTPUT = 2000
04 Jan 2025 16:21 - 04 Jan 2025 17:18 #318101 by PCW
Never mind, the PID stuff is all side stepped by:
net machine-is-on => hm2_[MESA](BOARD).0.stepgen.03.enable
net spindle-vel-cmd-rps => hm2_[MESA](BOARD).0.stepgen.03.velocity-cmd
net spindle-vel-fb-rps <= hm2_[MESA](BOARD).0.stepgen.03.velocity-fb
But it looks like machine-is-on is not connected, it probably should be something like:
net machine-is-on  <=motion.motion-enabled
Last edit: 04 Jan 2025 17:18 by PCW.
22 Jun 2025 15:11 #330699 by alexandrap
Hi, Sternfox.
Did you manage to create a working hal and ini file ?
It would be possible for you to attach it ?
23 Jun 2025 00:01 #330739 by Yaroslav
Hello. I have a lathe with a spindle on a servo motor and step/dir control and feedback via the encoder of the same drive on 7i96s. Everything works well. I also have an unfinished project on 7i97, where the spindle still works in an analog way. Step/dir is also planned. I can send the working files of the lathe.
23 Jun 2025 04:52 - 23 Jun 2025 05:00 #330748 by zmrdko
does it work now?
Last edit: 23 Jun 2025 05:00 by zmrdko.
23 Jun 2025 13:22 #330759 by Yaroslav
Lathe with Step/dir spindle.
08 Jul 2025 12:45 #331516 by alexandrap
Moderators: PCW, jmelson
Time to create page: 0.111 seconds
