- Hardware & Machines
- Driver Boards
- Error: undefined symbol: hm2_pktuart_setup_rx - while lading custom modbus.so
- Corne
14 Feb 2025 18:08 #321570
by Corne
Error: undefined symbol: hm2_pktuart_setup_rx - while lading custom modbus.so was created by Corne
I like to get some data out of my Servo driver (Bergerda SDF20NK9).
Followed all instructions according documented Mesa Modbus. Created an sdf_modbus.so (I made an exact copy as discribes in Mesa Modbus documentation.
If I execute: 'halcmd loadrt sdf_modbus' I get the following error: undefined symbol: hm2_pktuart_aetup_rx
I have seen this thread: Mesa modbus and pktUart where the same error message was reported by Donno but I can't reproduce his solution.
I use a Mesa 7i96s card.
Who can help me out?
- Thank you received: 5330
14 Feb 2025 18:13 #321571
Replied by PCW on topic Error: undefined symbol: hm2_pktuart_setup_rx - while lading custom modbus.so
That halcmd command is missing the port stanza
- Corne
14 Feb 2025 18:18 #321572
by Corne
Replied by Corne on topic Error: undefined symbol: hm2_pktuart_setup_rx - while lading custom modbus.so
Your right!
But also halcmd loadrt sdf_modbus ports=hm2_7i96s.0.pktuart.0 gives the same error.
14 Feb 2025 18:21 - 14 Feb 2025 18:27 #321573
Does your firmware have a pkt_uart?
Last edit: 14 Feb 2025 18:27 by PCW.
- Corne
14 Feb 2025 19:15 #321576
by Corne
yes.
I loaded 7i96sd_pktv2.bin and see the PktUARTRX and TX port (0) with mesaflash --readhmid --addr 10.10.10.10 --device 7i96s
- Corne
14 Feb 2025 19:16 #321577
by Corne
for the record, I'm running linuxcnc 2.9.4 on Debian bookworm
14 Feb 2025 19:25 #321579
x86 or ARM?
If you post the .mod file I can try and duplicate the issue
- Corne
14 Feb 2025 19:33 #321580
by Corne
I'm running x86
To be sure I have no errors in my mod file, I just copied the one from the Mesa Modbus documentation:
The format of the channel descriptors is:
{TYPE, FUNC, ADDR, COUNT, pin_name}
TYPE is one of HAL_BIT, HAL_FLOAT, HAL_S32, HAL_U32
FUNC = 1, 2, 3, 4, 5, 6, 15, 16 - Modbus commands
COUNT = number of coils/registers to read
#define MAX_MSG_LEN 16 // may be increased if necessary to max 251
static const hm2_modbus_chan_descriptor_t channels = {
/* {TYPE, FUNC, ADDR, COUNT, pin_name} */
// Create 8 HAL bit pins coil-00 .. -07 supplying the values of coils at 0x0000
{HAL_BIT, 1, 0x0000, 8, "coil"},
// Create 8 HAL bit pins input-00 .. -07 supplying the values of inputs at 0x0000
{HAL_BIT, 2, 0x0000, 8, "input"},
// Create a HAL pin to set the coil at address 0x0010
{HAL_BIT, 5, 0x0010, 1, "coil-0"},
// Create 8 HAL pins to set the coils at 0x0020
{HAL_BIT, 15, 0x0020, 8, "more_coils"},
// Create a scaled floating point pin calculated from input register 0x0100
{HAL_FLOAT, 4, 0x0100, 1, "float"},
// Create 4 unsigned integer HAL pins from the holding registers at 0x0200-0x203
{HAL_S32, 3, 0x0003, 4, "holding"},
// Create a single signed int HAL pin to control the register at 0x0300
{HAL_S32, 6, 0x0300, 1, "relay-3"},
// Create 7 scaled FP HAL pins to control holfing registers at 0x400-0x406
{HAL_FLOAT, 16, 0x0300, 1, "more_floats"},
14 Feb 2025 20:05 - 14 Feb 2025 20:21 #321582
That does not seem to compile
Can you try an example file from the modbus directory, say relayboard.mod
or alternatively here's a simple .mod file I am running right now (linuxCNC 2.9.4)
that works with the common 32in 32 out modbus modules from Eletechsup:
Needs to be renamed to mb25ioc32.mod before compiling with
modcompile mb25ioc32.mod
Last edit: 14 Feb 2025 20:21 by PCW.
- Corne
14 Feb 2025 20:38 #321584
by Corne
Now it's obvious i'm a newby. I don't know where to find your example. It doesn't looks to be on my machine.
Strange that the example I mentioned above does not work. I just did a complete fresh install of 2.9.4 and it compiled ok, but same error at loadrt.
- Driver Boards
