7i95 board for 5ABoB(not T or S) firmware missing
- Nathan40
24 Mar 2025 15:36 - 24 Mar 2025 15:37 #324788
by Nathan40
7i95 board for 5ABoB(not T or S) firmware missing was created by Nathan40
Hi all
i could not find 7i95 board with 5ABoB (not the T or S) board firmware on the mesa website. Please share if possible with stepgens for the 5ABoB with inputs.
Last edit: 24 Mar 2025 15:37 by Nathan40.
- Thank you received: 7490
24 Mar 2025 15:37 #324789
Replied by tommylight on topic 7i95 board for 5ABoB(not T or S) firmware missing
Did you use mesaflash to check what is already in it?
- Nathan40
24 Mar 2025 15:56 - 24 Mar 2025 15:59 #324792
by Nathan40
Replied by Nathan40 on topic 7i95 board for 5ABoB(not T or S) firmware missing
Hi
Thanks for your response. It has regular pins for the 7i95 hardware with the parallel ports having I/O pins.Please help with the bitfiles with stepgens ans inputs as they are not available on the mesa website.
Last edit: 24 Mar 2025 15:59 by Nathan40.
- Thank you received: 5334
24 Mar 2025 17:57 - 24 Mar 2025 18:02 #324800
Replied by PCW on topic 7i95 board for 5ABoB(not T or S) firmware missing
What I/O do you actually need?
The 7I95 is fairly limited so a full 5ABOB configuration will not fit.
5ABOB inputs will be available with the standard firmware
as are GPIO outputs. It may be possible to make a configuration
that fits and does what you need by eliminating unused features.
Last edit: 24 Mar 2025 18:02 by PCW.
- Nathan40
24 Mar 2025 18:01 #324803
by Nathan40
I need stepgens on 2 (step) 3 (direction) , 4 (step) 5 (direction), 6 (step) 7 (direction), 10 11 15 pins as inputs for the pins of 5 Abob.
24 Mar 2025 18:04 - 24 Mar 2025 18:25 #324804
The inputs already work.
That number of stepgens will not fit a standard 7I95 configuration
Do you use all the encoder channels?
Do you use the sserial channels?
(The added stepgens might fit by eliminating unused features)
Last edit: 24 Mar 2025 18:25 by PCW.
- Nathan40
24 Mar 2025 18:28 #324808
by Nathan40
I need the stepgens on the BoB for the 7i95.
24 Mar 2025 18:36 - 24 Mar 2025 19:12 #324810
When you say you want the stepgens on the BOB
do you mean you need 9 stepgens total or just
the three on the BOB?
If you need 9 stepgens total, some other feature like
encoders or sserial ports must go.
Last edit: 24 Mar 2025 19:12 by PCW. Reason: clarify
- Nathan40
25 Mar 2025 04:26 #324854
by Nathan40
That is correct. 9 stepgens (6 for the main hardware + 3 for the BoB).
- Nathan40
26 Mar 2025 06:05 #324941
by Nathan40
Please help as my project is hanging for few days now.
7i95 (not T or S )does not have any 5ABoB bitfiles on the mesa website.
Time to create page: 0.097 seconds
