Flyback diode mesa 7i95t
1 year 4 months ago #330041 by unknown
Replied by unknown on topic Flyback diode mesa 7i95t
The function of an optocoupler is to completely isolate one side of a circuit from another. Hence the large no copper regions under the device.
No amount of filtering, hoping nor thinking will provide this if the same supply is used or if 2 different supplied are used and their grounds connected.
Pickup a book, read & learn.
Eventually your mis advice will end with someone with less knowledge and experience than yourself having a bad time.
Those unseen electrons moving around can bite.
1 year 4 months ago #330084 by unknown
Connecting the wires "far from each other" from the same supply will do nothing.There is no electrical isolation. None whatsoever.
1 year 4 months ago #330086 by tommylight
Replied by tommylight on topic Flyback diode mesa 7i95t
More antennae to collect interference ...
OK for stuff with no big inductive loads, not OK otherwise to use long cables, neither is using more cables.
And mind the wiring loops.
The OP seems to have left the building due to bickering and useless replies, not nice.
1 year 4 months ago #330111 by unknown
Is it really bickering when correcting so much bad information from langdons ?
This is what I meant in my problem thread.
Apologies to the OP, just didn't want you to do anything that could cause issues.
Moderators: PCW, jmelson
Time to create page: 2.230 seconds
