Xilinx Zynq 7010 fpga crypto windfall boards
2 months 1 week ago #348955 by murdemon
2 months 1 week ago #348998 by murdemon
Pins for smart serial is in Pin descriptor from IDROM of ZYNQ hostmot2 FPGA, but in usag it show as just IOPort, why it is can happens? I doing some mistake , or it is some logic of work when nothink findout on smart serial?
ubuntu@arm:~$ ./start_linuxcnc.sh
This script only needs to be run once per shell session.
LINUXCNC - 2.9.10
Machine configuration directory is '/home/ubuntu/linuxcnc-dev/configs/test'
Machine configuration file is 'puma560.ini'
check_config: Unchecked: [KINS]KINEMATICS=genserkins
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(LIB): /home/ubuntu/linuxcnc-dev/lib/hallib/basic_sim.tcl
setup_kins: cmd=loadrt genserkins
userkKinematicsSetup:
emc/kinematics/userkfuncs.c max_joints=9 allow_duplicates=0
setup_kins: unknown [KINS]KINEMATICS=
Found file(REL): ./puma560_dh.hal
hm2/hm2_soc_ol: Low Level init 0.15
hm2/hm2_soc_ol: 34 HM2 Pin Descriptors:
hm2/hm2_soc_ol: pin 0:
hm2/hm2_soc_ol: Primary Tag: 0x03 (IOPort)
hm2/hm2_soc_ol: Secondary Tag: 0xC1 (Smart Serial Interface)
hm2/hm2_soc_ol: Secondary Unit: 0x00
hm2/hm2_soc_ol: Secondary Pin: 0x81 (tx0, Output)
hm2/hm2_soc_ol: pin 1:
hm2/hm2_soc_ol: Secondary Pin: 0x01 (rx0, Input)
hm2/hm2_soc_ol: pin 2:
hm2/hm2_soc_ol: pin 3:
hm2/hm2_soc_ol: pin 4:
hm2/hm2_soc_ol: Secondary Tag: 0x05 (StepGen)
hm2/hm2_soc_ol: Secondary Pin: 0x82 (Direction, Output)
hm2/hm2_soc_ol: pin 5:
hm2/hm2_soc_ol: Secondary Pin: 0x81 (Step, Output)
hm2/hm2_soc_ol: pin 6:
hm2/hm2_soc_ol: Secondary Unit: 0x01
hm2/hm2_soc_ol: pin 7:
hm2/hm2_soc_ol: pin 8:
hm2/hm2_soc_ol: Secondary Unit: 0x02
hm2/hm2_soc_ol: pin 9:
hm2/hm2_soc_ol: pin 10:
hm2/hm2_soc_ol: Secondary Unit: 0x03
hm2/hm2_soc_ol: pin 11:
hm2/hm2_soc_ol: pin 12:
hm2/hm2_soc_ol: Secondary Tag: 0x1A (Hostmot2 DPLL)
hm2/hm2_soc_ol: Secondary Pin: 0x82 (Ref Out Pin, Output)
hm2/hm2_soc_ol: pin 13:
hm2/hm2_soc_ol: Secondary Tag: 0x04 (Encoder)
hm2/hm2_soc_ol: Secondary Pin: 0x01 (A, Input)
hm2/hm2_soc_ol: pin 14:
hm2/hm2_soc_ol: Secondary Pin: 0x02 (B, Input)
hm2/hm2_soc_ol: pin 15:
hm2/hm2_soc_ol: Secondary Pin: 0x03 (Index, Input)
hm2/hm2_soc_ol: pin 16:
hm2/hm2_soc_ol: pin 17:
hm2/hm2_soc_ol: Secondary Tag: 0x06 (PWMGen)
hm2/hm2_soc_ol: Secondary Pin: 0x81 (Out0 (PWM or Up), Output)
hm2/hm2_soc_ol: pin 18:
hm2/hm2_soc_ol: pin 19:
hm2/hm2_soc_ol: pin 20:
hm2/hm2_soc_ol: Secondary Unit: 0x04
hm2/hm2_soc_ol: pin 21:
hm2/hm2_soc_ol: pin 22:
hm2/hm2_soc_ol: Secondary Unit: 0x05
hm2/hm2_soc_ol: pin 23:
hm2/hm2_soc_ol: pin 24:
hm2/hm2_soc_ol: Secondary Unit: 0x06
hm2/hm2_soc_ol: pin 25:
hm2/hm2_soc_ol: pin 26:
hm2/hm2_soc_ol: Secondary Unit: 0x07
hm2/hm2_soc_ol: pin 27:
hm2/hm2_soc_ol: pin 28:
hm2/hm2_soc_ol: pin 29:
hm2/hm2_soc_ol: pin 30:
hm2/hm2_soc_ol: pin 31:
hm2/hm2_soc_ol: pin 32:
hm2/hm2_soc_ol: pin 33:
hm2/hm2_soc_ol: Smart Serial Firmware Version 43
hm2/hm2_soc_ol: 34 I/O Pins used:
hm2/hm2_soc_ol: IO Pin 000 (GPIO0.P1-01): IOPort
hm2/hm2_soc_ol: IO Pin 001 (GPIO0.P1-14): IOPort
hm2/hm2_soc_ol: IO Pin 002 (GPIO0.P1-02): IOPort
hm2/hm2_soc_ol: IO Pin 003 (GPIO0.P1-15): IOPort
hm2/hm2_soc_ol: IO Pin 004 (GPIO0.P1-03): StepGen #0, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 005 (GPIO0.P1-16): StepGen #0, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 006 (GPIO0.P1-04): StepGen #1, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 007 (GPIO0.P1-17): StepGen #1, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 008 (GPIO0.P1-05): StepGen #2, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 009 (GPIO0.P1-06): StepGen #2, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 010 (GPIO0.P1-07): StepGen #3, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 011 (GPIO0.P1-08): StepGen #3, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 012 (GPIO0.P1-09): Hostmot2 DPLL #0, pin Ref Out Pin (Output)
hm2/hm2_soc_ol: IO Pin 013 (GPIO0.P1-10): Encoder #0, pin A (Input)
hm2/hm2_soc_ol: IO Pin 014 (GPIO0.P1-11): Encoder #0, pin B (Input)
hm2/hm2_soc_ol: IO Pin 015 (GPIO0.P1-12): Encoder #0, pin Index (Input)
hm2/hm2_soc_ol: IO Pin 016 (GPIO0.P1-13): IOPort
hm2/hm2_soc_ol: IO Pin 017 (GPIO0.P2-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 018 (GPIO0.P2-14): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 019 (GPIO0.P2-02): PWMGen #2, pin Out0 (PWM or Up) (Output)
hm2/hm2_soc_ol: IO Pin 020 (GPIO0.P2-15): StepGen #4, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 021 (GPIO0.P2-03): StepGen #4, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 022 (GPIO0.P2-16): StepGen #5, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 023 (GPIO0.P2-04): StepGen #5, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 024 (GPIO0.P2-17): StepGen #6, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 025 (GPIO0.P2-05): StepGen #6, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 026 (GPIO0.P2-06): StepGen #7, pin Direction (Output)
hm2/hm2_soc_ol: IO Pin 027 (GPIO0.P2-07): StepGen #7, pin Step (Output)
hm2/hm2_soc_ol: IO Pin 028 (GPIO0.P2-08): IOPort
hm2/hm2_soc_ol: IO Pin 029 (GPIO0.P2-09): Encoder #1, pin A (Input)
hm2/hm2_soc_ol: IO Pin 030 (GPIO0.P2-10): Encoder #1, pin B (Input)
hm2/hm2_soc_ol: IO Pin 031 (GPIO0.P2-11): Encoder #1, pin Index (Input)
hm2/hm2_soc_ol: IO Pin 032 (GPIO0.P2-12): IOPort
hm2/hm2_soc_ol: IO Pin 033 (GPIO0.P2-13): IOPort
hm2/hm2_soc_ol: registered
DUMMY DISPLAY MODULE, press to continue.
2 months 1 week ago #349017 by PCW
If the driver does not find a Sserial remote, it reverts the pins to GPIO
so that's expected if there is no remote connected/discovered.
2 months 6 days ago - 2 months 6 days ago #349020 by murdemon
It all working now. Have to change tri-state block in vivad. Will be update on cloud project Vivado and so on
Last edit: 2 months 6 days ago by murdemon.
2 months 6 days ago #349022 by meister
nice, it's time to build an addon board with IO's :)
2 months 5 days ago #349037 by murdemon
In really already have IOs on stmbl drive , now add webui interface, all work on board
Moderators: PCW, jmelson
Time to create page: 0.486 seconds
