Using Mesa 7i95T for laser + galvo (xy2-100) control
28 Jan 2026 22:07 #342104 by micklethenickel
Replied by micklethenickel on topic Using Mesa 7i95T for laser + galvo (xy2-100) control
If I were to try doing this with just the galvo hooked up to the 7I95T (no other peripheral steppers), would I still need the daughtercards? Also, where would I be able to find the xy2mod firmware needed for the 7I95T? I saw you had one for the 7I96 board, but it seems this cannot act as a drop-in replacement
28 Jan 2026 23:44 #342108 by PCW
Yes, you can steal 2 Step/Dir channels to support the 4 differential output signals
that XY2-100 needs. If you don't need the status data back from the galvanometer,
that's all that would be required. If you need the galvanometer status, you could
steal 1 of the 7I95T's RS-422 serial port RX pairs
I can make this firmware if needed
The following user(s) said Thank You: tommylight, phino
29 Jan 2026 00:16 #342109 by micklethenickel
Thanks! Yeah getting the firmware for this would be much appreciated :)
29 Jan 2026 00:20 #342110 by PCW
Do you need the galvo status?
29 Jan 2026 00:28 #342111 by micklethenickel
Yes
  • phino
  • Junior Member
  • Junior Member
29 Jan 2026 01:05 #342117 by phino
Would be great to have firmware for both option. Thanks for making the firmware!
Are there instructions somewhere for building the firmware for oneself?
29 Jan 2026 01:19 #342124 by PCW
7I95T configuration with last two stepgens replaced with XY2-100 galvanometer outputs
and serial 0 RX replaced with XY2-100 Status
File Name: 7i95t_xymodd.zip
File Size:281 KB
The following user(s) said Thank You: phino, micklethenickel
29 Jan 2026 01:24 #342125 by micklethenickel
Thank you so much!
29 Jan 2026 02:25 #342134 by PCW
Building  the bin files basically amounts to:
installing the Efinity too chain
unzipping the Mesa source for the particular card in to Efinitys project directory
Creating the desired pinout file for a particular configuration
(mainly a copy-past operation from existing pinout files)
adding the new pinout file to the project
including the new pinout file in the top level source
build
Note that I included the pinout source for the 7I95T  XY2-100 configuration
Moderators: PCWjmelson
Time to create page: 0.157 seconds
