Bitfile for 6i25+7i74+7i85
  • ChironFZ16
  • ChironFZ16's Avatar Topic Author
  • Senior Member
  • Senior Member
08 Aug 2025 02:18 #333027 by ChironFZ16
Bitfile for 6i25+7i74+7i85 was created by ChironFZ16
I would need a Bitfile for the 6i25, the 7i74 is on P3 and the 7i85 is on P2, if that possiple ?
08 Aug 2025 04:17 #333030 by PCW
Replied by PCW on topic Bitfile for 6i25+7i74+7i85
Sure, I'll try and do this sometime tomorrow
The following user(s) said Thank You: ChironFZ16
08 Aug 2025 14:13 #333048 by PCW
Its a bit of an odd configuration. is It the really a 7I85 + 7I74?
That would normally end up with  4 encoders and 13 sserial
channels, and no PWM or stepgens. Is this what you intended?
08 Aug 2025 14:27 #333050 by tommylight
Replied by tommylight on topic Bitfile for 6i25+7i74+7i85
I was wondering the same thing.
  • ChironFZ16
  • Senior Member
  • Senior Member
09 Aug 2025 08:05 - 09 Aug 2025 08:17 #333094 by ChironFZ16
Replied by ChironFZ16 on topic Bitfile for 6i25+7i74+7i85
Yes,forPWMs u.Servos i have 2 x 5i20
Last edit: 09 Aug 2025 08:17 by ChironFZ16.
09 Aug 2025 17:38 #333134 by PCW
File Name: 5i25_7i85_7i74d.zip
File Size:111 KB
5I25/6I25 config for 7I85 on P3 (ext DB25), 7I74 on P2 (internal header)
Only 3 sserial channels on the 7I85 (port 0) because of space considerations
All 8 sserial channels on port 1 (7I74)
  • ChironFZ16
  • Senior Member
  • Senior Member
10 Aug 2025 08:54 - 10 Aug 2025 09:26 #333149 by ChironFZ16
The next question is how do I get this activated, I still have two 7i66 and a 7i64 connected to the 7i74, which I can no longer see
The old config :
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i20
CONFIG="num_encoders=0 num_stepgens=0 sserial_port_1=021xxx,firmware=hm2/5i20/svst6_6_7i48.bit num_encoders=6 num_pwmgens=6 num_stepgens=0num_leds=0,firmware=hm2/5i20/svst6_6_7i48.bit num_encoders=0 num_pwmgens=0 num_stepgens=0num_leds=0"
[MACROS]
Old config:
Old config:
MesaCT:
Read HMID
Returned: Success
Configuration Name: HOSTMOT2
  BoardName : MESA5I25
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 17
  Clock Low frequency: 33.3333 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 33.333 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: MuxedQCount
  There are 4 of MuxedQCount in configuration
  Version: 4
  Registers: 5
  BaseAddress: 3600
  Module: MuxedQCountSel
  There are 1 of MuxedQCountSel in configuration
  Version: 0
  Registers: 0
  BaseAddress: 0000
  Module: SSerial
  There are 2 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       None
14                      1   IOPort       None
 2                      2   IOPort       None
15                      3   IOPort       None
 3                      4   IOPort       SSerial          0        RXData2         (In)
16                      5   IOPort       SSerial          0        TXData2         (Out)
 4                      6   IOPort       SSerial          0        RXData1         (In)
17                      7   IOPort       SSerial          0        TXData1         (Out)
 5                      8   IOPort       SSerial          0        RXData0         (In)
 6                      9   IOPort       SSerial          0        TXData0         (Out)
 7                     10   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 8                     11   IOPort       MuxedQCount      0        MuxQ-A          (In)
 9                     12   IOPort       MuxedQCount      0        MuxQ-B          (In)
10                     13   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
11                     14   IOPort       MuxedQCount      1        MuxQ-A          (In)
12                     15   IOPort       MuxedQCount      1        MuxQ-B          (In)
13                     16   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
IO Connections for P2
 1                     17   IOPort       SSerial          1        RXData0         (In)
14                     18   IOPort       SSerial          1        RXData1         (In)
 2                     19   IOPort       SSerial          1        RXData2         (In)
15                     20   IOPort       SSerial          1        RXData3         (In)
 3                     21   IOPort       SSerial          1        TXData0         (Out)
16                     22   IOPort       SSerial          1        TXData1         (Out)
 4                     23   IOPort       SSerial          1        TXData2         (Out)
17                     24   IOPort       SSerial          1        TXData3         (Out)
 5                     25   IOPort       SSerial          1        RXData4         (In)
 6                     26   IOPort       SSerial          1        RXData5         (In)
 7                     27   IOPort       SSerial          1        RXData6         (In)
 8                     28   IOPort       SSerial          1        RXData7         (In)
 9                     29   IOPort       SSerial          1        TXData4         (Out)
10                     30   IOPort       SSerial          1        TXData5         (Out)
11                     31   IOPort       SSerial          1        TXData6         (Out)
12                     32   IOPort       SSerial          1        TXData7         (Out)
13                     33   IOPort       SSerial          1        TXEn7           (Out)
Last edit: 10 Aug 2025 09:26 by ChironFZ16.
10 Aug 2025 13:29 #333158 by PCW
What was the previous configuration?
That is, what changed?
  • ChironFZ16
  • Senior Member
  • Senior Member
10 Aug 2025 23:38 #333188 by ChironFZ16
That was 5i25_7i74x2.bit, sserial_port_1=021xxx
10 Aug 2025 23:44 #333190 by PCW
Odd, do the 7I85 encoders work?
Maybe there's some meta-problem of some kind.
Moderators: PCW, jmelson
Time to create page: 0.905 seconds
