- Thank you received: 12
[HOSTMOT2]
DRIVER=hm2_pci
BOARD=5i20
CONFIG="num_encoders=0 num_stepgens=0 sserial_port_1=021xxx,firmware=hm2/5i20/svst6_6_7i48.bit num_encoders=6 num_pwmgens=6 num_stepgens=0num_leds=0,firmware=hm2/5i20/svst6_6_7i48.bit num_encoders=0 num_pwmgens=0 num_stepgens=0num_leds=0"
[MACROS]
Old config:
Old config:
MesaCT:
Read HMID
Returned: Success
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 4 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 2 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort None
14 1 IOPort None
2 2 IOPort None
15 3 IOPort None
3 4 IOPort SSerial 0 RXData2 (In)
16 5 IOPort SSerial 0 TXData2 (Out)
4 6 IOPort SSerial 0 RXData1 (In)
17 7 IOPort SSerial 0 TXData1 (Out)
5 8 IOPort SSerial 0 RXData0 (In)
6 9 IOPort SSerial 0 TXData0 (Out)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort MuxedQCount 0 MuxQ-A (In)
9 12 IOPort MuxedQCount 0 MuxQ-B (In)
10 13 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 1 MuxQ-A (In)
12 15 IOPort MuxedQCount 1 MuxQ-B (In)
13 16 IOPort MuxedQCount 1 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 1 RXData0 (In)
14 18 IOPort SSerial 1 RXData1 (In)
2 19 IOPort SSerial 1 RXData2 (In)
15 20 IOPort SSerial 1 RXData3 (In)
3 21 IOPort SSerial 1 TXData0 (Out)
16 22 IOPort SSerial 1 TXData1 (Out)
4 23 IOPort SSerial 1 TXData2 (Out)
17 24 IOPort SSerial 1 TXData3 (Out)
5 25 IOPort SSerial 1 RXData4 (In)
6 26 IOPort SSerial 1 RXData5 (In)
7 27 IOPort SSerial 1 RXData6 (In)
8 28 IOPort SSerial 1 RXData7 (In)
9 29 IOPort SSerial 1 TXData4 (Out)
10 30 IOPort SSerial 1 TXData5 (Out)
11 31 IOPort SSerial 1 TXData6 (Out)
12 32 IOPort SSerial 1 TXData7 (Out)
13 33 IOPort SSerial 1 TXEn7 (Out)
