extra axis on 7i96 with bob
- PaulQUE
17 Aug 2025 19:33 #333571
by PaulQUE
extra axis on 7i96 with bob was created by PaulQUE
hello, I have a working config on my cnc machine using a 7i96 (no s) thats using 4 stepgens and pmw output for the spindle and it's been working greaat for a few years now.
I need the four stepgens to square up the gantry (XYYZ kinematics) and I am looking at options to add a 5th stepgen to drive a rotary axis using a chinese Bob connected to the P1 expension port.
Am i correct it seems the simplest is to move the spindle pwm control to the BOB to use the 5 stepgens directly on the card?
what firmware would i need to flash on the card, and is there a exemple config that displays how to drive the spindle pwm output from the BOB?
thanks for the help
thanks for the help
- Thank you received: 5334
18 Aug 2025 00:14 #333593
Replied by PCW on topic extra axis on 7i96 with bob
If this is the standard SainSmart V2 5 Axis BOB, then
7i96_5abob_d.bit firmware would be the appropriate.
The existing hal file should be close (the PWM output just moves
to the BOB) There may be polarity/frequency changes needed
with the PWM output.
You would need to add the 5th axis stuff to the hal/ini files
- PaulQUE
29 Aug 2025 19:07 #334102
by PaulQUE
Replied by PaulQUE on topic extra axis on 7i96 with bob
thanks for the answer, I tried flashing the firmware with mesa flash and all I get is "no 7I96 board found"
adress is 10.10.10.10,
running --device ethernet-- returns "ETH device 7I96 at ip=10.10.10.10"
any idea what that could come from?
- Thank you received: 7490
29 Aug 2025 19:18 #334105
Replied by tommylight on topic extra axis on 7i96 with bob
What version of mesaflash are you using?
29 Aug 2025 19:25 #334106
What command line did you use?
Something like:
mesaflash --device 7i96 --addr 10.10.10.10 --write 7i96_5abob_d.bit --reload
should work
Something like:
should work
- PaulQUE
29 Aug 2025 19:28 #334107
by PaulQUE
mesa flash version 3.4.6
I tried adding --reload but i still get the same answer, I also tried using 7i96_2
29 Aug 2025 19:30 #334109
Did you add the "--addr 10.10.10.10"
- PaulQUE
29 Aug 2025 19:32 #334110
by PaulQUE
yes I ran your exact command
29 Aug 2025 19:38 #334111
Strange, does:
mesaflash --device ethernet --addr 10.10.10.10 --write 7i96_5abob_d.bit --reload
work?
work?
- PaulQUE
29 Aug 2025 19:45 #334113
by PaulQUE
"no ethernet board found",
I must admit I am not super linux savy, could i be doing something wrong related to either the boards' jumper or some other config related issue?
Time to create page: 0.335 seconds
