extra axis on 7i96 with bob
1 year 2 months ago #334119 by PCW
Replied by PCW on topic extra axis on 7i96 with bob
Fairly mysterious...
Does LinuxCNC run properly?
1 year 2 months ago #334123 by PaulQUE
Replied by PaulQUE on topic extra axis on 7i96 with bob
Yes, I've been using the machine since 2022 with no issue using the stock firmware, i'm only trying to use mesaflash now to use a fifth stepgen. is there something with my linux install that could have gone wrong?
1 year 2 months ago #334125 by PCW
Strange issue...
You might try updating mesaflash to the current version:
github.com/LinuxCNC/mesaflash
(scroll down to bottom for build instructions)
1 year 2 months ago #334128 by PaulQUE
trying to do this, I realize the computer I use seems to have some broader networking issue, I usually use it offline, I connected it to wifi but I have no acces to the internet, any leads to where this might come from? wrong ip adress setup on my pc?
1 year 2 months ago #334129 by PCW
The IP address for the WIFI should be assigned automatically via DHCP
not something you normally need to change.
Do make sure that you are not using wicd for network setup
it broken and does not allow a DHCP WIFI connection to coexist
with a static Ethernet connection.
1 year 2 months ago #334145 by PaulQUE
thank you for the help, I did a fresh install using the latest image and got mesaflash to work, the proper firmware is now on the board.
I have a few more questions before I fry my card
when connecting the bob o the 7i96 in what position should W8 be?
what is the correct adress for the P1/PWM pin on the bob?
Moderators: PCW, jmelson
Time to create page: 0.278 seconds
