- Hardware & Machines
- Driver Boards
- (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
- kb58
- Thank you received: 4
25 Sep 2025 18:22 - 25 Sep 2025 19:27 #335419
by kb58
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60 was created by kb58
First post, so be gentle - also, if this is in the wrong sub-forum, feel free to move it.
Back story: I'm building a wire EDM machine based upon Mike Bax's BX18 arc generator. He supplies modified LinuxCNC code, including initialization code for the stepper drivers. It's nearly done but I've run up against a problem with the drivers.
The problem: Mike wrote code for the ECT60 (closed loop driver) version, configuring it to run open-loop steppers. Silly me thought that since they're open loop steppers, there was no reason to spend the extra money on the ECT model, so I bought the ECR (open loop) model. Unfortunately, they're apparently different enough that the ECR gets stuck in the "Pre-Operation" phase during initialization, and neither Mike nor I can figure out why.
We both looked through the XML .ini code and we can't find anything that would cause it to fail. What's a bit concerning however, is that the online manuals are missing at least two sections regarding registers 0x60FE, and 0x6077. It makes me wonder if perhaps more information is missing that could explain why this isn't working.
Obviously the "easy button" is to replace the ECR units with ECT units. I would gladly do so if I had a use for the ECRs, but I do not. Throwing another $200 at this project is a bitter pill - plus I'm stubborn - and I would like to figure this out instead.
Anyone have any ideas?
Note: This is my first interaction with both LinuxCNC (or any form of Linux) and XML, making it much more challenging.
Thanks!
Thanks!
Last edit: 25 Sep 2025 19:27 by kb58.
- Thank you received: 4152
25 Sep 2025 20:06 #335430
Replied by rodw on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
6077 is actual torque which probably can't be read without encoders so delete it. Not sure about 60fe, I never used it.
I would get the docs from rtelligent for both drives. there isn't really much difference between the ECT and ECR aside from some I/O and encoders.
Sometimes you need to reset to factory defaults as covered in the docs.
The following user(s) said Thank You: kb58
- Hakan
- Thank you received: 454
25 Sep 2025 20:55 #335432
by Hakan
Replied by Hakan on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
We discussed 60fe some time ago forum.linuxcnc.org/ethercat/50492-etherc...ligent-ecr60-outputs digital outputs.
What are the errors you get? Linuxcnc output and Ethercat output from "sudo dmesg"
Initial thought is that this drive should work with default settings, like the ECT60 does.
- kb58
25 Sep 2025 20:58 #335433
by kb58
Replied by kb58 on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Thank you for your reply. I have asked rtelligent for the correct manuals but don't hold out much hope for a response.
I completely agree that the two versions are so similar that they should "just work", but the ECRs disagree, hah. I'll try deleting the 6077 reference and cross my fingers.
I would post the code in question but don't know how to get it from the Linux mini PC out to a Windows PC so I can post it. I can post literally screenshots (via camera), if it's helpful.
The developer had me start LinuxCNC from a command window with the following command. I did, and will try posting the results here, but the forum is blocking me, saying that it has "too many links" (there aren't any):
/usr/bin/linuxcnc '/home/edmuser/linuxcnc/configs/BaxEDM-2axis-WireEDM/2axis-WireEDM.ini'
- kb58
25 Sep 2025 20:59 - 25 Sep 2025 21:13 #335434
by kb58
I'll copy the debug output to a file and attach it...
Last edit: 25 Sep 2025 21:13 by kb58.
The following user(s) said Thank You: Hakan
- kb58
25 Sep 2025 21:15 #335436
by kb58
Here you go, see attached.
- Hakan
25 Sep 2025 21:18 #335437
by Hakan
Don't see anything wrong there.
To try to diagnose this, we would need to see
ini file
hal file
ethercat-conf.xml file
and last say 40 lines of ouput from the command "sudo dmesg"
ini file
hal file
- kb58
25 Sep 2025 22:23 - 25 Sep 2025 23:27 #335439
by kb58
Files attached.
Last edit: 25 Sep 2025 23:27 by kb58.
- Hakan
26 Sep 2025 07:56 - 26 Sep 2025 11:45 #335446
by Hakan
"Invalid output mapping" is what it says. infosys.beckhoff.com/english.php?content...stem/1058704779.html
What I think you should do is minimize the config to one slave, slave 0, and make that go OP.
Comment out all references to the other slaves lcec.0.1 and lcec.0.2 in the hal files.
Comment out/remove all sdoconfigs from ethercat-conf.xml and only leave slave 0 in there.
Comment out pdos, leave 6040, 6060, 607a, 6041,6061,6064 only.
With that, the slave should go to OP mode, check with "ethercat slaves".
Then gradually bring back the mods you took out, and fix what doesn't work.
Last edit: 26 Sep 2025 11:45 by Hakan. Reason: link to beckhoff
- kb58
26 Sep 2025 15:03 #335456
by kb58
Thank you very much! Though I don't know Linux or XML, I'm familiar with other languages so feel assured that I can get myself in way over my head! First thing I'll do is save off a backup, then give your suggestion a go.
Thanks again.
Thanks again.
- Driver Boards
Time to create page: 0.317 seconds
