- Hardware & Machines
- Driver Boards
- (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
- Hakan
- Thank you received: 454
30 Sep 2025 07:57 - 30 Sep 2025 07:59 #335607
by Hakan
Replied by Hakan on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
It's the Twincat XAE to download.
You also tried to reset to factory defaults?
Also doing "ethercat rescan" won't hurt, might help.
Last edit: 30 Sep 2025 07:59 by Hakan.
- kb58
30 Sep 2025 14:59 - 30 Sep 2025 18:04 #335626
by kb58
Replied by kb58 on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
I don't know the syntax for writing a line of code that causes a factory reset.
I'll try downloading the XAE code and print out the config file to see if there's anything different.
I'll also try "ethercat rescan", thanks.
Just to prolong the drama a bit, the Amazon seller of the ECT60 drive reported that a week-long national holiday is coming up, so they won't be able to ship the drivers until they return - and cancelled my order. Perhaps this is the universe telling me to keep working on the ECR drivers...
Last edit: 30 Sep 2025 18:04 by kb58.
- kb58
30 Sep 2025 17:27 - 01 Oct 2025 18:49 #335633
by kb58
Installed the TwinCAT app. Good lord, it's an entire development package and I'm clueless about where to start. I was hoping that it would have "add device" and to specify how it acts, then it generates config code. Maybe it can but I have no idea how to do so.
Also, started LinuxCNC and in a terminal window, commanded "ethercat rescan." No change in status.
Last edit: 01 Oct 2025 18:49 by kb58.
- kb58
01 Oct 2025 18:16 - 01 Oct 2025 19:05 #335674
by kb58
The developer took pity on me and sent a stripped down version of his initialization code. It fails in exactly the same way. Maybe I'm doing something really fundamentally wrong, except that since the arc generator boots up successfully to OP makes me again suspect that the ECT and ECR models differ in some way not documented. This could explain why the developer - who know the system and code inside and out - can't get it working either...
Oh, as a sanity check, I swapped in a brand new ECR unit that's never been run - same issue.
Is there any way to request the error code from the slave via a Geany terminal, to have the system tell me why it's unhappy?
Last edit: 01 Oct 2025 19:05 by kb58.
- Hakan
02 Oct 2025 17:00 #335733
by Hakan
Did you check product code vs pid?
I just downloaded the ERC60V202.xml esi file, and there is says product code x0A880001,
you have 0x0A880002 in the ethercat-conf.xml you supplied in one of the early posts.
Check Product code and Vendor Information vs vid and pid.
You find it with "ethercat slaves -v" alternatively "lcec_configgen"
The following user(s) said Thank You: kb58
- kb58
02 Oct 2025 18:03 - 04 Oct 2025 18:44 #335735
by kb58
I checked my config file and confirmed that it was 0xA8800002. Changed it to -1 and reloaded LinuxCNC. Checked the LEDs and
the status lights are now solid green, no longer blinking. Very tentatively clicked on Toggle Machine Power and immediately heard the steppers start making noise, unlike before. Cautiously brought up Manual Control and tried stepping X and Y in both directions ..... both work.
THANK YOU THANK YOU THANK YOU!
I was in the process teaching myself Geany line commands that report register contents. The plan was to start poking at them, hoping to have it tell me what the problem was. While I would like to say that I'd find the above eventually, I might also have given up in frustration and ordered the ECT version.
I would send you flowers and a fruit basket but don't want to cause trouble at your end
Thank you again - very much - and now I can get on with completing this beast of a project! Just so I know, where did you find the ERC60V202.xml esi file? The rTelligent site has zero downloads on the product page other than the manual.
Last edit: 04 Oct 2025 18:44 by kb58.
- kb58
02 Oct 2025 18:34 #335738
by kb58
Is there a way to mark this thread as solved?
- Thank you received: 7490
02 Oct 2025 18:38 #335739
Thank you.
Replied by tommylight on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Done.Is there a way to mark this thread as solved?
Thank you.
- kb58
03 Oct 2025 01:11 #335756
by kb58
Thanks, one of the most annoying things on forums are threads about some problem you yourself are having, and either they just end without resolution, or perhaps worse, end with "it's been figured out, thanks." Ugh... HOW?
- Driver Boards
Time to create page: 0.116 seconds
