- Thank you received: 454
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
1 year 1 month ago #335493
by Hakan
Replied by Hakan on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Can you comment out nets and things in the hal file to also remove the digital in and out?
rodw also mentioned doing a factory reset of the drive by writing to a sdo. Can you do that too?
1 year 1 month ago - 1 year 1 month ago #335495
by kb58
Replied by kb58 on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
I will try that, yes. What is meant by "nets and stuff?"
I will also try the factory reset but am unsure how well that will work. What I mean is, let's say that I issue the factory reset command upon entry to the code. Then, the following code will immediately configure the driver into a "not factory reset" condition. Is the thinking that something was changed that has not been corrected and that a factory reset is the only way to fix it?
Last edit: 1 year 1 month ago by kb58.
1 year 1 month ago #335496
by Hakan
I specifically was after the digital IO like here
Put a # in front of the net lines. "and stuff" is vague for anything else that might cause problem for linuxcnc to start.
The logic of your machine is not correct then, but that's not important now. Get it to start only.
#net sig300 lcec.0.0.digital-inputs => baxedmstatus.0.ect60inputs
net sig301 baxedmstatus.0.wirenok => qtvcp_embed.wirenok_led baxedmfeedcontrolV02.0.wireNOK
net sig302 baxedmstatus.0.wirefeedon => qtvcp_embed.wirefeed_led qtvcp_embed.led_wire
#net sig303 baxedmstatus.0.ect60-0-outputs => lcec.0.0.set60FE-1
#net sig304 baxedmstatus.0.ect60-1-outputs => lcec.0.1.set60FE-1
1 year 1 month ago - 1 year 1 month ago #335497
by kb58
Understood. I tried the above - no change, status light still blinking, still in "PREOP".
Regarding a factory reset, I'm not sure how to apply it. See attached screenshot:
1 year 1 month ago - 1 year 1 month ago #335498
by kb58
FWIW, here are the files in question as of now, with the requested lines commented out or removed. I must still be missing something - or the manual leaves out critical information...
1 year 1 month ago - 1 year 1 month ago #335503
by Hakan
Do you have the errors from syslog?
I would like to see the 60fe and 60fd sdos and pdos out specifically and only the 6 mentioned PDOs in there.
Here is a document on how to use the drive in TwinCAT.
shopcdnpro.grainajz.com/category/409767/...%8D%97-%E8%8B%B1.pdf
I guess it is worthwhile to check it works there.
Last edit: 1 year 1 month ago by Hakan.
Time to create page: 0.272 seconds
