- Thank you received: 454
(Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
1 year 4 weeks ago #335733
by Hakan
Replied by Hakan on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Did you check product code vs pid?
I just downloaded the ERC60V202.xml esi file, and there is says product code x0A880001,
you have 0x0A880002 in the ethercat-conf.xml you supplied in one of the early posts.
Check Product code and Vendor Information vs vid and pid.
You find it with "ethercat slaves -v" alternatively "lcec_configgen"
The following user(s) said Thank You: kb58
1 year 4 weeks ago - 1 year 4 weeks ago #335735
by kb58
Replied by kb58 on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
I checked my config file and confirmed that it was 0xA8800002. Changed it to -1 and reloaded LinuxCNC. Checked the LEDs and
the status lights are now solid green, no longer blinking. Very tentatively clicked on Toggle Machine Power and immediately heard the steppers start making noise, unlike before. Cautiously brought up Manual Control and tried stepping X and Y in both directions ..... both work.
THANK YOU THANK YOU THANK YOU!
I was in the process teaching myself Geany line commands that report register contents. The plan was to start poking at them, hoping to have it tell me what the problem was. While I would like to say that I'd find the above eventually, I might also have given up in frustration and ordered the ECT version.
I would send you flowers and a fruit basket but don't want to cause trouble at your end
Thank you again - very much - and now I can get on with completing this beast of a project! Just so I know, where did you find the ERC60V202.xml esi file? The rTelligent site has zero downloads on the product page other than the manual.
Last edit: 1 year 4 weeks ago by kb58.
1 year 4 weeks ago #335738
by kb58
Is there a way to mark this thread as solved?
1 year 4 weeks ago #335739
Thank you.
Replied by tommylight on topic (Solved) Initialization code for a rintelligent ECT60 fails when run on an ECR60
Done.Is there a way to mark this thread as solved?
Thank you.
1 year 4 weeks ago #335756
by kb58
Thanks, one of the most annoying things on forums are threads about some problem you yourself are having, and either they just end without resolution, or perhaps worse, end with "it's been figured out, thanks." Ugh... HOW?
Time to create page: 0.310 seconds
