MESA 7I92 programming
30 Oct 2025 23:24 #337550 by PCW
Replied by PCW on topic MESA 7I92 programming
Not sure what the issue is, it works for me (LinuxCNC 2.9.4).
did you choose a lathe XZ configuration at the beginning?
Also note that stepgen 5 is used for the charge-pump
so you need to enable al 6 stepgens to have that available
The following user(s) said Thank You: TJ
31 Oct 2025 21:40 - 31 Oct 2025 21:43 #337608 by TJ
Replied by TJ on topic MESA 7I92 programming
I reinstalled the full Linux, because I probably already messed everything up.
Now the configuration wizard worked right away and everything works fine.
Thanks again for your help.
Last edit: 31 Oct 2025 21:43 by TJ.
Moderators: PCW, jmelson
Time to create page: 0.172 seconds
