Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
- Thank you received: 5328
31 Dec 2025 15:55 #340778
Replied by PCW on topic Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
It could be wiring (serial cable, missing FieldA or FieldB power on 7I84)
or hal file setup.
or hal file setup.
- TripleM
- Thank you received: 3
03 Jan 2026 15:10 #340919
by TripleM
Replied by TripleM on topic Bitfile for Mesa 7i96s + 7i85 (+Modbus (PKT-Pin))
I have checked the power and the cable, that look fine. (FieldA (24V) or FieldB (5V) power on 7I84)
This is the load line in the hal file:
Do I have to add anything if the 7i84 is connected via a daughter card?
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=6 num_pwmgens=1 num_stepgens=5 sserial_port_0=2xxxx"Do I have to add anything if the 7i84 is connected via a daughter card?
03 Jan 2026 16:02 #340922
The 7I84 should connect to 7I85 TB2 pins 10..16
There are also some difference in the VHDL source and mesaflash pin list
1. You have 2 null modules descriptors before the PKTUARTS. I don't think this will
work as the module scan normally ends at the first null
2. The source you posted has sserial channels starting at channel 1 rather than 0
(so sserial_port_0=2xxxx" would disable the first channel (1) on the 7I85)
- TripleM
07 Jan 2026 14:41 #341129
by TripleM
The 7I84 is connected to 7I85 TB2 pins 10..16.
for test I have flashed the 7i96s + 7i85 firmware.
So I think this is the correct load line?! Or have I misunderstood something?
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=6 num_pwmgens=1 num_stepgens=9 sserial_port_0=x2xxxx"Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: OutM
There are 1 of OutM in configuration
Version: 0
Registers: 1
BaseAddress: B000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 9 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InM
There are 1 of InM in configuration
Version: 0
Registers: 5
BaseAddress: 8500
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I96_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-1 0 IOPort InM 0 Input0_EncA0 (In)
TB3-2 1 IOPort InM 0 Input1_EncB0 (In)
TB3-3 2 IOPort InM 0 Input2_EncA1 (In)
TB3-4 3 IOPort InM 0 Input3_EncB1 (In)
TB3-5 4 IOPort InM 0 Input4_EncA2 (In)
TB3-6 5 IOPort InM 0 Input5_EncB2 (In)
TB3-7 6 IOPort InM 0 Input6_EncA3 (In)
TB3-8 7 IOPort InM 0 Input7_EncB3 (In)
TB3-9 8 IOPort InM 0 Input8 (In)
TB3-10 9 IOPort InM 0 Input9 (In)
TB3-11 10 IOPort InM 0 Input10 (In)
TB3-13,14 11 IOPort SSR 0 Out-00 (Out)
TB3-15,16 12 IOPort SSR 0 Out-01 (Out)
TB3-17,18 13 IOPort SSR 0 Out-02 (Out)
TB3-19,20 14 IOPort SSR 0 Out-03 (Out)
TB3-21,22 15 IOPort OutM 0 Output4 (Out)
TB3-23,24 16 IOPort OutM 0 Output5 (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3 17 IOPort StepGen 0 Step/Table1 (Out)
TB1-4,5 18 IOPort StepGen 0 Dir/Table2 (Out)
TB1-8,9 19 IOPort StepGen 1 Step/Table1 (Out)
TB1-10,11 20 IOPort StepGen 1 Dir/Table2 (Out)
TB1-14,15 21 IOPort StepGen 2 Step/Table1 (Out)
TB1-16,17 22 IOPort StepGen 2 Dir/Table2 (Out)
TB1-20,21 23 IOPort StepGen 3 Step/Table1 (Out)
TB1-22,23 24 IOPort StepGen 3 Dir/Table2 (Out)
TB2-2,3 25 IOPort StepGen 4 Step/Table1 (Out)
TB2-4,5 26 IOPort StepGen 4 Dir/Table2 (Out)
TB2-7,8 27 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-10,11 28 IOPort MuxedQCount 2 MuxQ-B (In)
TB2-13,14 29 IOPort MuxedQCount 2 MuxQ-IDX (In)
TB2-16,17 30 IOPort SSerial 0 RXData0 (In)
TB2-18,19 31 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 32 IOPort SSerial 0 TXEn0 (Out)
Internal 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01 34 IOPort SSerial 0 RXData5 (In)
P1-02/DB25-14 35 IOPort SSerial 0 TXData5 (Out)
P1-03/DB25-02 36 IOPort SSerial 0 RXData4 (In)
P1-04/DB25-15 37 IOPort SSerial 0 TXData4 (Out)
P1-05/DB25-03 38 IOPort SSerial 0 RXData3 (In)
P1-06/DB25-16 39 IOPort SSerial 0 TXData3 (Out)
P1-07/DB25-04 40 IOPort SSerial 0 RXData2 (In)
P1-08/DB25-17 41 IOPort SSerial 0 TXData2 (Out)
P1-09/DB25-05 42 IOPort SSerial 0 RXData1 (In)
P1-11/DB25-06 43 IOPort SSerial 0 TXData1 (Out)
P1-13/DB25-07 44 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P1-15/DB25-08 45 IOPort MuxedQCount 0 MuxQ-A (In)
P1-17/DB25-09 46 IOPort MuxedQCount 0 MuxQ-B (In)
P1-19/DB25-10 47 IOPort MuxedQCount 0 MuxQ-IDX (In)
P1-21/DB25-11 48 IOPort MuxedQCount 1 MuxQ-A (In)
P1-23/DB25-12 49 IOPort MuxedQCount 1 MuxQ-B (In)
P1-25/DB25-13 50 IOPort MuxedQCount 1 MuxQ-IDX (In)Please Log in or Create an account to join the conversation.
07 Jan 2026 15:40 #341131
If you are not sure of sserial port locations sure you could always:
sserial_port_0=00000000
Also on mesaflash you can show the daughtercard pinout with (for example):mesaflash --device Ethernet --addr 10.10.10 --dbnbame3 7i85 --readhmid
- TripleM
08 Jan 2026 21:20 - 08 Jan 2026 21:20 #341178
by TripleM
We seem to have strayed from the topic...
I tried again today and simply tried other serial channels. When I was at SSerial 5 (7i85 TB1, pin 17-24), my 7i84 was found. So it seems that either there is something wrong with the DB25 - ID24 connection cable (I measured it pin by pin) or with the 7i85 itself. I'm not sure how to check that yet...
But back to the topic. The bit files work.
Thank you very much for your help.
Last edit: 08 Jan 2026 21:20 by TripleM.
Time to create page: 0.186 seconds
