The 7I84 is connected to 7I85 TB2 pins 10..16.
for test I have flashed the 7i96s + 7i85 firmware.
Configuration Name: HOSTMOT2
BoardName : MESA7I96
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: OutM
There are 1 of OutM in configuration
Version: 0
Registers: 1
BaseAddress: B000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: StepGen
There are 9 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InM
There are 1 of InM in configuration
Version: 0
Registers: 5
BaseAddress: 8500
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I96_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-1 0 IOPort InM 0 Input0_EncA0 (In)
TB3-2 1 IOPort InM 0 Input1_EncB0 (In)
TB3-3 2 IOPort InM 0 Input2_EncA1 (In)
TB3-4 3 IOPort InM 0 Input3_EncB1 (In)
TB3-5 4 IOPort InM 0 Input4_EncA2 (In)
TB3-6 5 IOPort InM 0 Input5_EncB2 (In)
TB3-7 6 IOPort InM 0 Input6_EncA3 (In)
TB3-8 7 IOPort InM 0 Input7_EncB3 (In)
TB3-9 8 IOPort InM 0 Input8 (In)
TB3-10 9 IOPort InM 0 Input9 (In)
TB3-11 10 IOPort InM 0 Input10 (In)
TB3-13,14 11 IOPort SSR 0 Out-00 (Out)
TB3-15,16 12 IOPort SSR 0 Out-01 (Out)
TB3-17,18 13 IOPort SSR 0 Out-02 (Out)
TB3-19,20 14 IOPort SSR 0 Out-03 (Out)
TB3-21,22 15 IOPort OutM 0 Output4 (Out)
TB3-23,24 16 IOPort OutM 0 Output5 (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3 17 IOPort StepGen 0 Step/Table1 (Out)
TB1-4,5 18 IOPort StepGen 0 Dir/Table2 (Out)
TB1-8,9 19 IOPort StepGen 1 Step/Table1 (Out)
TB1-10,11 20 IOPort StepGen 1 Dir/Table2 (Out)
TB1-14,15 21 IOPort StepGen 2 Step/Table1 (Out)
TB1-16,17 22 IOPort StepGen 2 Dir/Table2 (Out)
TB1-20,21 23 IOPort StepGen 3 Step/Table1 (Out)
TB1-22,23 24 IOPort StepGen 3 Dir/Table2 (Out)
TB2-2,3 25 IOPort StepGen 4 Step/Table1 (Out)
TB2-4,5 26 IOPort StepGen 4 Dir/Table2 (Out)
TB2-7,8 27 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-10,11 28 IOPort MuxedQCount 2 MuxQ-B (In)
TB2-13,14 29 IOPort MuxedQCount 2 MuxQ-IDX (In)
TB2-16,17 30 IOPort SSerial 0 RXData0 (In)
TB2-18,19 31 IOPort SSerial 0 TXData0 (Out)
Internal-TXEn 32 IOPort SSerial 0 TXEn0 (Out)
Internal 33 IOPort SSR 0 AC Ref (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01 34 IOPort SSerial 0 RXData5 (In)
P1-02/DB25-14 35 IOPort SSerial 0 TXData5 (Out)
P1-03/DB25-02 36 IOPort SSerial 0 RXData4 (In)
P1-04/DB25-15 37 IOPort SSerial 0 TXData4 (Out)
P1-05/DB25-03 38 IOPort SSerial 0 RXData3 (In)
P1-06/DB25-16 39 IOPort SSerial 0 TXData3 (Out)
P1-07/DB25-04 40 IOPort SSerial 0 RXData2 (In)
P1-08/DB25-17 41 IOPort SSerial 0 TXData2 (Out)
P1-09/DB25-05 42 IOPort SSerial 0 RXData1 (In)
P1-11/DB25-06 43 IOPort SSerial 0 TXData1 (Out)
P1-13/DB25-07 44 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P1-15/DB25-08 45 IOPort MuxedQCount 0 MuxQ-A (In)
P1-17/DB25-09 46 IOPort MuxedQCount 0 MuxQ-B (In)
P1-19/DB25-10 47 IOPort MuxedQCount 0 MuxQ-IDX (In)
P1-21/DB25-11 48 IOPort MuxedQCount 1 MuxQ-A (In)
P1-23/DB25-12 49 IOPort MuxedQCount 1 MuxQ-B (In)
P1-25/DB25-13 50 IOPort MuxedQCount 1 MuxQ-IDX (In)
