7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
13 Feb 2026 16:15 #342894 by freemoore
Hi PCW,Thanks for that. There's a problem with the sserial port; with the previous firmware (attached), the system as it's currently wired inc. the hal line:
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=6 sserial_port_0=0000000" works and allows us to reference the 7i84 e.g.: hm2_7i97.0.7i84.0.3.output-00
Changing only the firmware to the one you posted above, lcnc fails to start with error:
twopass: Error in file ./morb01_IO_7i84.hal:
    Pin 'hm2_7i97.0.7i84.0.3.output-00' does not exist
this is with all wiring identical. close checking of the readhmid output and manuals suggests that the sserial port settings should remain the same - is this expected?
13 Feb 2026 17:09 #342895 by PCW
Sorry, mismatch between advertised clock and real clock
so the baud rates were all off...
 Denser configurations like this have a slower clock to meet timing
and this is the first time I have made on of these configs, and I had
not quite gotten al the ducks in a row...
This _should_ be better
File Name: 7i97t_7i74...2-13.zip
File Size:317 KB
13 Feb 2026 21:31 #342914 by freemoore
Great, that's got the sserial and pktuart ports appearing and working, thank you for the quick response.
We have 3x identical modbus cards to communicate with. Using mb2hal it was possible to address each one but I can't see how to do that using mesa_modbus - is there a way to talk to different addresses over a single pktuart port? This may be a question for Andy Pugh...
Is this possible in hm2-modbus?
13 Feb 2026 21:46 - 13 Feb 2026 21:47 #342917 by PCW
It should be possible with hm2_modbus,
(as long as the devices sharing a link have the same baud rate)
mesa-modbus only supports one device (per host UART)
Last edit: 13 Feb 2026 21:47 by PCW.
The following user(s) said Thank You: freemoore
Moderators: PCW, jmelson
