did you turn on power to the Mesa card before starting linuxcnc?
yep, first thing I tried (a lot of times I got an error then I realized I forgot to switch on the machine)
Whats does the command:
ip a
report?
What happens if you:
ping 10.10.10.10
This is what I get with "ip a" and giving a ping:
joccnc@JocCnc:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether e8:4e:06:84:dc:c9 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.245/24 brd 192.168.1.255 scope global dynamic eth0
valid_lft 863950sec preferred_lft 863950sec
inet6 fd59:b8bd:be6f:0:6bdd:2ca7:6e73:aa7b/64 scope global noprefixroute dynamic
valid_lft 7152sec preferred_lft 3552sec
inet6 fe80::6ed6:c856:a0cb:2db8/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 70:85:c2:6a:f0:3d brd ff:ff:ff:ff:ff:ff
inet 10.10.10.11/8 brd 10.255.255.255 scope global eth1
inet6 fe80::8ede:25a1:ff4d:99b4/64 scope link
joccnc@JocCnc:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10): 56 data bytes
64 bytes from 10.10.10.10: icmp_seq=0 ttl=64 time=0.779 ms
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.418 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.402 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.424 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.365 ms
eth0 is my second network card, I use it to reach my NAS, my LAN and the WEB
eth1 is the integrated network card, used by Mesa
giving the ping 10.10.10.10 I get response from Mesa
I just don't understand why eth1 report IP 10.10.10.11, when my hal file is set 10.10.10.10, and ping to 10.10.10.10 works.
BTW, after these tests I tried to start LinuxCNC, I get again an error message, but this time no mention about the MAC (is correctly reported), now the error is about HM2 registration:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/joccnc/linuxcnc/configs/Prova01'
Machine configuration file is 'Prova01.ini'
INIFILE=/home/joccnc/linuxcnc/configs/Prova01/Prova01.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Prova01.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:45:59
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
board fails HM2 registration
Running HAL shutdown script
Killing task linuxcncsvr, PID=1208
hm2: unloading
