too long hm2_7i97.0.read.tmax or something else?
7 months 1 week ago #344731 by PCW
That does not look bad but the max servo thread time shows the issue
( 1624528  clocks at 1.7 Ghz is ~.95 ms)
It may be that the CPU/BIOS-Setup are simply not capable of the needed
network performance for a 1 KHz servo thread.
A last ditch is to use a newer kernel as the 6.1 kernel in the LinuxCNC distribution
is fairly bad latency wise.
7.0.0-rc1-rt1 #1 SMP PREEMPT_RT
Is the current one
The following user(s) said Thank You: m0602232
7 months 1 week ago #344737 by rodw
What CPU do you have? How many cpus does it report?
what does echo $(nproc) say?
Its possible you are trying to isolate a nonexistent core
7 months 6 days ago #344755 by m0602232
PCW: Thanks for that, I'll consider changing kernel, or maybe trying with another pc.
rodw: processor: Intel(R) Core(TM) i5-8400T CPU @ 1.70GHz, echo $(nproc) prints 5.
7 months 6 days ago #344761 by rodw
thanks, 6 core PC with one isolated = 5 available so that's right. i5 should be fine
What network card? is it Realtek?
I've been researching this today. Here are a few more obscure settings that may help where eno1 is the NOC name from ip a
sudo sysctl -w net.core.busy_read=50 sudo sysctl -w net.core.busy_poll=50 sudo sysctl -w kernel.sched_rt_runtime_us=-1 sudo ethtool --set-eee en01 eee off sudo ethtool -K eno1 gro off lro off tso off
7 months 6 days ago #344762 by m0602232
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: Lenovo Ethernet Connection (7) I219-V
Flags: bus master, fast devsel, latency 0, IRQ 120
Memory at b1000000 (32-bit, non-prefetchable) [size=128K]
Capabilities: <access denied>
Kernel driver in use: e1000e
Kernel modules: e1000e
eee was already off, not sure about gro, lro or tso but I will try with them disabled also.
7 months 6 days ago #344765 by rodw
Looking at your first post, its not network related. Note those previous settings do not persist. Running out of ideas. As PCW mentioned ensure the NIC interrupt is pinned to isolated core 5
You mentioned graphics so you probably have an Intel i915 GPU which hangs on my PC. Add these to grub to lock it downi915.enable_dc=0 i915.enable_fbc=0 i915.enable_psr=0
Moderators: PCW, jmelson
Time to create page: 0.381 seconds
