Encoder wiring - Mesa 7i33
- Thank you received: 5018
25 Mar 2011 23:42 #8092
Replied by andypugh on topic Re:Encoder wiring - Mesa 7i33
Fordperf393W wrote:
You can zero the encoder (set the "reset" bit high through a HAL pin). Generally you don't, the encoders just hold their value and can count for about a milliion years before they run out of counts. (Seriously, the counts are held in a 64-bit number).
Normally you zero-out the axis using either "home" or "touch-off". The former says "this is zero in the absolute machine axis positions" and the latter means "for this job, I want zero to be here". Think of it as the difference between winding a manual machine to the end stops, or tweaking the micrometer thimble on the handwheel.
EMC2 has several coordinate sets available, so you can set up all 4 corners of a machine vice or whatever to suit. I suspect it is a bit early in your build to worry about it, but here is a page which explains: wiki.linuxcnc.org/emcinfo.pl?CoordinateSystems
Yes, in about three different ways, depending on what you are wanting to do.is it possible to zero out an axis at its current position?
- Fordperf393W
26 Mar 2011 00:15 #8095
by Fordperf393W
Replied by Fordperf393W on topic Re:Encoder wiring - Mesa 7i33
I assume this is because of the sample gcode loaded, i get a following error when i try to home an axis. or 'cant execute mdi command when not homed'
26 Mar 2011 00:34 #8096
just clicking the "home" button for each axis will make that problem go away.
(Or you can put the NO_FORCE_HOMING option in for testing)
linuxcnc.org/docs/html/config_ini_config...b:%5BTRAJ%5D-section
Time to create page: 0.095 seconds
