Mori MV 35/40 retrofit
- clkeck1
18 Sep 2011 00:20 #13241
by clkeck1
Replied by clkeck1 on topic Re:Mori MV 35/40 retrofit
I changed the w1,2,&3 jumpers to turn off USB and select different baud rates. I also tryed turning off power thru USB w9? And using external power. All gave me the same results.
Cory
Cory
- Thank you received: 2162
18 Sep 2011 00:20 - 18 Sep 2011 00:22 #13242
Replied by cmorley on topic Re:Mori MV 35/40 retrofit
in your HAL file I see the 7i64 pin names are wrong the should have the name gpio in them eg:
hm2_5i23.0.7i64.0.0.gpio.00.in
Oh i see further down they are right.
Last edit: 18 Sep 2011 00:22 by cmorley.
- schmidtmotorworks
- Thank you received: 6
18 Sep 2011 00:22 - 18 Sep 2011 00:23 #13243
by schmidtmotorworks
Replied by schmidtmotorworks on topic Re:Mori MV 35/40 retrofit
I think I found the problem, we are sharing files, it seems to be some property of the file causing the problem.
From reading the error log, it appears that it can't open the file.
I tried making a new file and pasting the content from Corys hal file
and it couldn't read it either.
Then I tried the same but pasted in the contents of the known good framework file, same problem.
So I think there is some property about the file that maybe us LINUX
beginners don't know about.
I did this:
1. Start with the original framework hal file that we got that worked.
2. Test it to make sure it works.
3. Select all, delete everything in the file
4. Open Corys hal file select all, copy, then paste all into the the
(now empty) framework file.
5. Test it in EMC2
Axis opens no error message.
I did this:
5. Test it in EMC2
Last edit: 18 Sep 2011 00:23 by schmidtmotorworks.
18 Sep 2011 00:35 #13244
What did you set the w1,2,3 to?
- clkeck1
18 Sep 2011 00:52 #13245
by clkeck1
I tryied
down,up,up 921 KBaud
up,up,down 5 MBaud
Shouldn't the config line and bit file set the number and type of pins available when you look at the hal configurator?
If so it shouldn't it be a software issue?
up,up,down 5 MBaud
- Thank you received: 5272
18 Sep 2011 02:01 #13248
Replied by PCW on topic Re:Mori MV 35/40 retrofit
For SSERIAL/SSLBP the baud rate must be 2.5 M Baud (UP DOWN UP)
all other jumpers left in default positions
you must have the 7I44 connected to the last 5I23 connector with the SVSS6_8 config
you should get red lights on the 7I64 when you power up and green lights when EMC starts
- Thank you received: 4994
18 Sep 2011 15:48 #13257
Replied by andypugh on topic Re:Mori MV 35/40 retrofit
The 7i64s are not being found.
The first thing I would try would be to change num_sserials=3 to num_sserials=8 in the HAL file. Perhaps the 7i64s are not plugged in where you think they are.
Also, as Pete poined out, are you sure that the 7i44 is connected to the corrrect header?
18 Sep 2011 17:26 #13261
Like I said,
1. Make sure that the 7I64 baud rates are set to 2.5 M baud UP/DOWN/UP) and that all other jumpers are in default positions (as shown in 7I64 manual)
2. Make sure the 7I44 is connected to the last 5I23 connector (IO 48..71)
3. At this point when you power up the system, the 7I64s should show red LEDs
4 Make sure your CAT5 cables have all 8 wires and are straight through cables,
NOT crossover cables (random cables that came with your router will likely not work)
- clkeck1
18 Sep 2011 17:48 #13263
by clkeck1
I set the baud rate to 2.5M this morning and its working great.
should have a machine that at least moves today.
- clkeck1
19 Sep 2011 19:20 #13313
by clkeck1
I’m getting ready to adjust my servo drives for +-10V. I’m going to unhook the servos from the ball screws, apply 10V to the input and adjust to 1000rpm.
Is there a way inside or outside of emc to “manually” apply 10V out of the 7i48?
Time to create page: 0.116 seconds
