Re:CHNC-1 Retrofit & Upgrades
14 years 3 months ago #21839 by bobinater
Hey rob any chance you may have some pics of the air control section of the lathe
I would like to get a look at what you did, I think I will have plenty of air to run this thing providing I
get all of the leaks repaired I have a 125 gallon air compressor that puts out about 70-90 cfm
hopefully that will be enough.
Bob
14 years 3 months ago #21840 by robh
Replied by robh on topic Re:CHNC-1 Retrofit & Upgrades
i iwll have a look i might have to snap afew when i have a moment tho
yea we have a large compressure like that if u have no leaks or can stop the closer leaking ull be ok..
but find piston is always on,
so we have a hydrovane compressor which easy keeps up with it we stick one,.. but we have alot of other things on in shop too , a bunch of mills and laths
14 years 3 months ago #21841 by bobinater
That would be great thanks I think i will disconnect the outlet line on each component to
figure out exactly what goes to what, ie collet closer parts catcher part off ect.
I will keep all posted on the progress, getting new camera this weekend so lots of pics to come next week.
thanks all
Bob
14 years 3 months ago #21845 by BigJohnT
The CHNC is an air hog the biggest leaker is the collet closer and the runner up is the tool turret cushion. I've completely rebuilt my collet closer and it still leaks like a sieve when open. It's OK when closed...
I have a 175psig 15CFM Ingersol Rand two stage piston compressor with a 60 gallon tank and the compressor kicks on every few minutes it seems while the CHNC is running.
14 years 3 months ago #21849 by bobinater
Hey john
is the collet closer like a cnc mill with an ATC it vents air when changing tools or is there something I should know
I.e would it be worthwhile to replace the whole thing with a Dorian and hook it up to the solenoid
or is there a chance that I can still get a rebuild kit for mine?
bob
14 years 3 months ago #21850 by BigJohnT
Your questions don't make sense... the collet closer on the back of the spindle I got replacement o-rings and quad rings from McMaster Carr. The o-rings came in packs of 25 so I have plenty left over. The collet closer (mine anyway) leaks a small amount when closed and leaks a lot when open... I'm not sure if that is a flush like a ATC does when the tool holder comes out but that does make some sense if you have a bar feeder.
The tool changer is not too bad but the cushion leaks air all the time. I would not trade it for a manual tool holder.
Time to create page: 0.176 seconds
